Error in Gcode file? Operation failed (Reason:err 1)
"Failed to get file info for ...gcode" Operation failed (Reason:err 1)
When I upload a gcode file I get the above error. (see Error Code.PNG) However the file successfully uploads. When I simulate printing the file, the web interface intermittently looses connection with the board and I have to emergency stop the board to reconnect. Unfortunately the gcode file is too large to upload here (4,612KB)
Board: Duet WiFi 1.02 or later + DueX5
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
Duet WiFi Server Version: 1.23
PrusaSlicer 2.2.0
Kossel Delta with Diamond HotendI edit the gcode in notepad++ prior to upload as I am simulating colour changes in the slicer using different tools but I am using a single mixing head tool on the printer; I search and replace T14, T15, T16 etc with T0. I have done this previously without error. (see Model.PNG). I have repeated this carefully and he error still occurs.
I have tried uploading files that I have previously printed and they print ok.
I have re-sliced the model and the error still occurs. The start and end of the file looks ok; I don't think that it has been truncated.
When I download the file from the web interface the file size is the same and it doesn't appear to be corrupted.
I have tried slicing a different model (with PrusaSlicer), that I have previously printed and it starts the print ok.
Main difference is that I haven't tried this many tools in the slicer before. I have previously used 13 but this time 22, but I rename all the tools to T0 anyway. I have checked the mixing ratio (M567) code for typos and can't see any. This a test print.
The file name is long "Colours 14 to 22 - Cylinder - Real Filament CYM 22 Colour Idealised.gcode" so I tried shortening it to "shortfilename.gcode" but the same errors occur.
I have printed larger file sizes.config.g and M122 output attached.
What else should I try?
Best regards James
I'm curious what version of DWC you're using, and can you upload the gcode file somewhere and link it? Or compress it, change the extension to txt, and try uploading it here. It may compress down enough to upload it.
Hi @Phaedrux Thanks for your attention.
I am using DWC 2.0.7.
The forum software will not allow me to upload a .zip file so I have changed the extension to .txt. You will need to change it back.Colours 14 to 22 - Cylinder - Real Filament CYM 22 Colour Idealised.txt
Otherwise, I have shared the uncompressed file on google drive.
I am happy to put it somewhere else if it is easier.https://drive.google.com/file/d/1zkOpH-vyU0qr0ptCABs9MZBd2GLNo8oo/view?usp=sharing
I think the next thing to try would be to have a fresh install and upgrade to the latest version (3.1.1) and do all the required config.g updates.
Thanks
James
Thanks for the file. I have reproduced the problem and I am investigating it.
This line in the GCode file is triggering the error:
; filament used [mm] = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1685.8, 1264.3, 1264.2, 1264.1, 1264.0, 1263.9, 1263.8, 893.5, 1029.2
At the same time as renumbering the tools, you should delete the 13 leading zeros from that line to get:
; filament used [mm] = 1685.8, 1264.3, 1264.2, 1264.1, 1264.0, 1263.9, 1263.8, 893.5, 1029.2
I have made the modification to the gcode file and I am now printing. Thank you.
Out of interest was it the number of items in the list that was causing the problem or the fact that the entries were zero?
Will this issue still exist when I upgrade to 3.1.1. ?
Thanks again
James
The number of items in the list was too large. It will be fixed in release 3.2, also in 3.1.2 if there is one. However, even with that fix the computed filament requirement would be wrong because of the tool renumbering, and that would caused the percent complete and print end time estimations to go wrong.
@dc42 Ok, does that mean that it would be better to define multiple tools in the config.g but have them refer to the same hardware?
M563 P0 S"Diamond 1" D2:3:4 H3 F0
M567 P0 E0.33:0.33:0.34
M563 P1 S"Diamond 2" D2:3:4 H3 F0
M567 P1 E0.98:0.01:0.01
M563 P2 S"Diamond 3" D2:3:4 H3 F0
M567 P2 E0.01:0.98:0.01
M563 P3 S"Diamond 4" D2:3:4 H3 F0
M567 P3 E0.01:0.01:0.98
etc
@JUNK said in Error in Gcode file? Operation failed (Reason:err 1):
etcThat's pretty much what I do. Here is the relevant part of my current config.g
M563 P0 S"Black" D0:1:2:4:5 H1 ; Define tool 0 (drive 3 not used)
G10 P0 X0 Y0 ; Set tool 0 axis offsets
M567 P0 E1.00:0.00:0.00:0.00:0.00 ; Set mixing ratios for tool 0
M563 P1 S"Red" D0:1:2:4:5 H1 ; Define tool 1
G10 P1 X0 Y0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
M567 P1 E0.00:1.00:0.00:0.00:0.00 ; Set mixing ratios for tool 1
M563 P2 S"Yellow" D0:1:2:4:5 H1 ; Define tool 2
G10 P2 X0 Y0 ; Set tool 2 axis offsets
G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
M567 P2 E0.00:0.00:1.00:0.00:0.00 ; Set mixing ratios for tool 2
M563 P3 S"Blue" D0:1:2:4:5 H1 ; Define tool 3
G10 P3 X0 Y0 ; Set tool 3 axis offsets
G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
M567 P3 E0.00:0.00:0.00:1.00:0.00 ; Set mixing ratios for tool 3
M563 P4 S"White" D0:1:2:4:5 H1 ; Define tool 4
G10 P4 X0 Y0 ; Set tool 4 axis offsets
G10 P4 R0 S0 ; Set initial tool 4 active and standby temperatures to 0C
M567 P4 E0.00:0.00:0.00:0.00:1.00 ; Set mixing ratios for tool 4
M563 P5 S"Orange" D0:1:2:4:5 H1 ; Define tool 5
G10 P5 X0 Y0 ; Set tool 5 axis offsets
G10 P5 R0 S0 ; Set initial tool 5 active and standby temperatures to 0C
M567 P5 E0.00:0.50:0.50:0.00:0.00 ; Set mixing ratios for tool 5
M563 P6 S"Purple" D0:1:2:4:5 H1 ; Define tool 6
G10 P6 X0 Y0 ; Set tool 6 axis offsets
G10 P6 R0 S0 ; Set initial tool 6 active and standby temperatures to 0C
M567 P6 E0.00:0.50:0.00:0.50:0.00 ; Set mixing ratios for tool 6
M563 P7 S"Green" D0:1:2:4:5 H1 ; Define tool 7
G10 P7 X0 Y0 ; Set tool 7 axis offsets
G10 P7 R0 S0 ; Set initial tool 7 active and standby temperatures to 0C
M567 P7 E0.00:0.00:0.50:0.50:0.00 ; Set mixing ratios for tool 7
M563 P8 S"Pink" D0:1:2:4:5 H1 ; Define tool 8
G10 P8 X0 Y0 ; Set tool 8 axis offsets
G10 P8 R0 S0 ; Set initial tool 8 active and standby temperatures to 0C
M567 P8 E0.00:0.50:0.00:0.00:0.50 ; Set mixing ratios for tool 8
Thanks, I think it was your blog post that I followed when I first set my printer up. Thank you for that.
It looks like I made a mistake when I drifted from your recommendations.
I was trying to simplify my config.g and have all the colour selections dealt with by the slicer. I would still like to do that, but I think that I will override the mixing ratios in the gcode and have all my tools defined in the config.g as generic. I am guessing that the filament estimates are based on the tools rather than the gcode. I will have to investigate and experiment further. (just thinking out loud)Thanks
@JUNK It depends what it is that you want to achieve and there are usually several options to achieve the same objective. If the object is made up several distinct shapes which have to be different colours, then I find it easiest to create separate stl files for each piece and assign a specific tool to each of those pieces. But I may change the mixing ratio for those specific tools in the slicer start gcode. If the object just has bands of colour or perhaps "fades" from one colour to another, then I find it easier to use one tool and post process the gcode file to change the mixing ratio every "n" layers. Having said all that, I never take much notice of the filament based estimates. So they might "get confused" if one changes the mixing ration within the gcode file.
One thing to be aware of is that the latest firmware versions now have a limit of 50 tools (number 0 to 49 IIRC) but in earlier firmware, no such limit existed. It shouldn't be a problem but just be aware of the new limitations.
@deckingman Good points. Thank you for the information. I am currently subscribed to the "Diamond Hotend users" and the "3d printing multi material and multi coloured" groups on Facebook. Can you recommend anywhere else to follow?
No sorry. I don't "do" social media.
