    Not reading config.g on startup.
    2955
    • Boilermaker
      Boilermaker last edited by
      Just got the duetWifi. First time user and first time 3d printer. Anyway, everything is wired up and I'm trying to go through the Get Connected guide, but when I send a M503 Command I'm getting a Configuration file not found! I hooked the ssd card up to my computer and it has the sys/config.g file in there. Any ideas?
      • T3P3Tony
        Welcome
        What does the firmware report when you send M21?
        Can you copy call the contents of the SD card into a temporary folder on your computer, then format the card, the copy everything back please.
        If that does not work then if you have another <32GB uSD card you can use to test please try that.
        Duet Hardware Designer
        www.duet3d.com
        • Boilermaker
          SENDING:M21
          Cannot initialise SD card 0: Card is unusable
          I'll try that and let you know how it goes.
          • Boilermaker
            What Format should I format it to?
            • T3P3Tony
              FAT
              www.duet3d.com
              • T3P3Tony
                Oh wait what size card do you have? if 4GB or> then FAT32
                www.duet3d.com
                • Boilermaker
                  Ok I tried that. Still no luck. I tried a different SD card and still no luck. Its still giving me the same error.
                  • T3P3Tony
                    Ok I think you have a faulty SD card slot. can you contact who you bought the board from and ask for a replacement under warranty referencing this forum thread.
                    www.duet3d.com
                    • Boilermaker
                      ok. thanks. I will do that.
                      • Boilermaker
                        So I have board number 2 now, and so far it appears I have the same issue. Refusing to believe I have two boards with this issue, I'm trying to re-flash the firmware, but so far no luck. After I re-flash it and press reset it won't connect. I'm going to try somemore tonight, but is it possible I have two boards now that won't read from the SD card? This is getting frustrating.
                        • deckingman
                          deckingman last edited by
                          @Boilermaker:
                          Dumb question I know but your not accidentally pressing "erase" as well or instead of "reset" are you? The buttons are very close together. In any case, I don't think you need to press reset after re-flashing the firmware.
                          • Boilermaker
                            @deckingman:
                            @Boilermaker:
                            No the erase button is placed back a little on this version of the board, so it would be difficult to press the erase button accidentally. I was following the wiki about pressing reset, but I'll try it tonight without pressing reset.
                              If you have re-flashed with 1.18.1 firmware and you were previously using an older version, and you are using a Windows usb host computer, did you install the new device driver as described in the upgrade notes?
                              • Boilermaker
                                @dc42:
                                I think it previously already had 1.18.1 firmware, but I'm just trying anything at this point. I did install the device driver. I tried using the new Bossa on my Mac, and I've tried using the Sam-ba 2.16 on windows 10 virtual machine on my mac. On the windows machine I installed the device driver.
                                • Boilermaker
                                  Ok. I've tried the 1.18.1 firmware and the new 1.19 beta, and either one will not connect after I refresh. I tried it without refreshing but it won't connect that way either. Any ideas? I'm afraid I'm going to have to return this board as well.
                                    Are you able to connect via USB? If so, run M115 to confirm which firmware version you are running, because there have been big changes in the 1.19beta.
                                    • Boilermaker
                                      No I can't. The only way it lets me connect is if I erase and then reset. I can't get it to boot up with the firmware.
                                      • Dougal1957
                                        Dougal1957 last edited by
                                        Have you checked the size of the Firmware download from github to make sure you have actually got the BIN File and not the webpage
                                        • Boilermaker
                                          @Dougal1957:
                                          Yeah I checked that. I'll look again tonight, but I did look at that.
                                            Does any sort of port, or an unknown device, show up in Device Manager (if you are using Windows) when you connect the Duet via USB after flashing the new firmware?
                                            • Dougal1957
                                              Also check that you re-named the files mind that wont matter if your loading the FW By Bossac or Samba
                                              • Boilermaker
                                                @Dougal1957:
                                                I've tried both Boassac and Samba. Neither one seems to work. I tried renaming the files before using Bossac and Samba, doesn't seem to matter.
                                                • Boilermaker
                                                  @dc42:
                                                  No it doesn't. The windows is a VM on my mac that I can control where the USB ports connect and as soon as I reset the connection goes away and doesn't show up on the mac or the windows.
                                                    If it doesn't even show up as a COM port or unknown USB device, that suggests that the file you have flashed is not a valid firmware files for that board.
                                                    The DuetWiFiFirmware-1.18.1.bin file you downloaded should be 263Kb (268,852 bytes) long.
                                                    Also, please make sure that the M552 S1 command in config.g is commented out with a semicolon at the start of the line. WiFi firmware that doesn't match the main firmware can prevent the board running when the WiFi is enabled.
                                                    btw it's now possible to flash Duet WiFi firmware using the Bossa program from Shumatec, and there is a build of that program available for Mac.
                                                    • Boilermaker
                                                      So I was finally able to get the firmware reloaded. But now I'm getting as before where it says it cannot find the config file.
                                                      M503
                                                      SENDING:M503
                                                      M21
                                                      SENDING:M21
