    Nozzle's Z-coordinate Up & Down when moving across X-axis?
    • Ubelherz
      Ubelherz last edited by
      I am using an FLSUN QQ-S Pro Delta printer w/ a Duet 2 Wifi board & a BLTouch, and whenever I attempt to move the nozzle across the X-axis, Z goes up when X+50, and down when X-50... But going from Y-50 and Y+50 has no issues. Any inputs appreciated!
      config.g file:
      G29 S1 ; enables mesh leveling
      M550 P"Duet1" ; set printer name
      M665 R142.212 L280.5 B120.0 H368.28300 X0 Y0 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 A+0.00 B+0.00 ; put your endstop adjustments here, or let auto calibration find them
      M551 P"d00rst0p" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X101.50 Y101.50 Z101.50 E540.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X600 Y600 Z600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M221 S73 D0 ; sets extrusion factor of extruder to 73 percent
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P9 C"zprobe.in+zprobe.mod" H5 F600 T1500 ; set Z probe type to bltouch and the dive height + speeds(diveheight=H probingspeed=F meshbedspeed=T)
      G31 P25 X0 Y45.5 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M307 H0 A12.4 C33.7 B1 D3.1 S1 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H1 A340 B0 C140 D5.5 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M501
      M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on
      M563 P0 F0 S"Side Fans" ; define tool 0, uses extruder drive 0, heater1 and fan0
      M563 P2 H1 S"J-head Heater";
      M563 P1 D0 S"Extruder" ; creates tool 1 with extruder titled extrusion
      T1
      M302 ;yes
      bed.g file:
      G28 ; home all towers
      ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y109.9 H0 Z-99999
      G30 P1 X92.5 Y-64.95 H0 Z-99999
      G30 P2 X-92.5 Y-64.95 H0 Z-99999
      G30 P3 X0 Y64.9 H0 Z-99999
      G30 P4 X56.21 Y-32.45 H0 Z-99999
      G30 P5 X-56.21 Y-32.45 H0 Z-99999
      G30 P6 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
        Phaedrux Moderator @Ubelherz last edited by
        @Ubelherz said in Nozzle's Z-coordinate Up & Down when moving across X-axis?:
        First off, don't load the heightmap at boot up. Only load it after you've used the z probe to define where Z0 is. Loading it at startup can lead to some unintended z offsets. A good place to load it is in the slicer start gcode after Z0 has been defined by the probe using G30.
        So for a delta...
        G28 to home the towers
        G32 to auto calibrate
        G30 at the center of the bed
        G29 S1 to load the heightmap
        This also means that you may need to redo the heightmap.
        Also, moving the Z axis depending on bed position sounds a lot like the effects of mesh compensation. What does your heightmap look like? Does it match to how the nozzle is moving?
        • Ubelherz
          Ubelherz last edited by Ubelherz
          This is currently how it looks
          It does in fact match up with the way the nozzle is moving*
