Need help with initial setup.
So I finally have everything wired up and it powers up nicely. No sparks. Lights are all on that should be on. Can't get anything to move. I'm getting some error message that all axes aren't homed. Not sure where to go from here.
Sorry, It's a Corexy setup with duet 2 wifi controller.
@rsbkh said in Need help with initial setup.:
thats normal; set up your endstops and homing fixes it.
to override the safeguards see
M564 H0
https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
You can start here:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinterThe axes can be homes by pressing one of the orange the buttons. ("HOME X" ...)
@Chriss No, they don't work. Tried that and nothing happens.
then your endstops are likely not set up right. post your config and homeall files?
