    Putting a potentiometer on a hall sensor
    436
    • bigwood247undefined
      bigwood247
      Is there a way to add a potentiometer on this hall effect sensor that I want to use as a z sensor for auto bed leveling I want to put magnets under my bed as calibration points
      • piperswundefined
        pipersw
        hall sensor output is digital, I don't understand what you would do with a potentometer.
        Have you the reference of the board, or the datasheet, schematic ?
        • A Former User?
          A Former User
          hall sensors can be analouge, and the one on the picture probably is, using an opamp as a comparitor to make it act like a digital output.
          the output labeled A0 is probably the analouge output, but i don't understand why OP can't use the digital output for probing?
            bigwood247
            Yeah I think this on can have a digital or analog signal but I want to add a potentiometer to it so u can adjust the trigger distance ither closer or farther
              bigwood247
              Like this hall sensor has a pot built into it to adjust the trigger distance
                It might be possible to add a potentiometer, but I can't say how to do it without a schematic of the board.
                  bigwood247
                  I'll try to get that schematic but I'm thinking it might be hard to get lol
                  zaptaundefined 1 Reply Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @bigwood247
                    @bigwood247, you can try bending the sensor in/out for minor adjustment but not too many times.
                      bigwood247
                      So I bought diff hall endstops that I can add a external potentiometer to so now i know i can adjust the trigger distance with my external potentiometer the three holes u see in the above pic are where u solder the pot to
