    Fan short circuit, how to fix?
    25
    2.4k
    • carfnannundefined
      carfnann
      Hi
      I was changing my heatsink fan and did a short circuit on the wire (with a nice spark)...
      Board seems ok, I can Home All, launch heating on Tool and Bed but I have no fan working now...
      I have 2 fan on Always On and 2 on Pwm fan.
      What can I do to fix my fan? is there a fuse to change?
      Thanks
        jay_s_uk
        What board are you using?
        • carfnannundefined
          carfnann
          oops sorry, I'm using a Duet 2 WiFi
          • chrishammundefined
            chrishamm administrators
            If you have a v1.03 or newer, I think you have to replace a fuse. See https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams There is a blade fuse in the middle for the fans.
            Duet software engineer
            • carfnannundefined
              carfnann
              Thanks!
              Indeed, I've found the fuse. it is broken...
              unfortunately it is not a common fuse... I've check in auto store and the mini fuse start at 3A
              I would have to order online and wait weeks 😞
              • A Former User?
                A Former User @carfnann
                @carfnann said in Fan short circuit, how to fix?:
                while its probably not supported both the fan mosfet and the traces* on the board can deal with 3A, so in theory the the fuse (or the fan wiring) should fail before the board if you were to use a 3A fuse while you wait, and a fault develops. On the other hand odds are the mosfet for the fan in question is also blown, so I'd probably use a 3A just to test even if not for prints.
                *) according to https://www.4pcb.com/trace-width-calculator.html
                edit: if you find somewhere that fix motorcycles, they might have 1A fuse
                • en_passantundefined
                  en_passant
                  feeling @carfnann's pain as I'm trying to find the same fuse! Easy to finds 3A+ (even 2A on Amazon), but 1A not so.
                  Hoping mine will just be the fuse and not the mosfet as I wasn't playing with it and short it (what's more, since I've had the Duet wifi... it's never had a fan plugged into it! 😮)
                  Where about is that guy out of interest?
                  e_p
                  A Former User? Karmaundefined 2 Replies Last reply Reply Quote 0
                  • A Former User?
                    A Former User @en_passant
                    @en_passant said in Fan short circuit, how to fix?:
                    if the short circuit curren't didn't pass through the mosfet then its probably okay, the other way around the mosfet usally fail before the fuse.
                    sharing OPs general location might be a good idea, myself and others may also have a fuse to spare nearby.
                    en_passantundefined 1 Reply Last reply Reply Quote 0
                      en_passant @A Former User
                      @bearer said in Fan short circuit, how to fix?:
                      If you should happen to find another, I know someone in London who'd be grateful! 😉
                      e_p
                      • Karmaundefined
                        Karma @en_passant
                        @en_passant That very weird, I was able to easily find a 1amp mini fuse on Amazon. I pretty much did the same thing as OP. Got a very nice spark. I was so freaked out that I may have fried my board or something. Then I Googled it and found out about the fuse. Checked it and sure enough, it was blown. Ordered new fuse, only could get it with 10 in a pack. lolz, I guess I have a few extra tries to see some sparks fly. J/K.
                        If you would like and it is not against the forum's rules, I could post you the link to what I bought to replace my fuse.
                        en_passantundefined 1 Reply Last reply Reply Quote 1
                          en_passant @Karma
                          @Karma
                          Please, yeah. (Not sure it's against forum rules, but don't think so...)
                          I've found 1 - but it's on eBay from China and going to take a month to arrive!
                          e_p
                          Karmaundefined 1 Reply Last reply Reply Quote 0
                          • Karmaundefined
                            Karma @en_passant
                            @en_passant Admins, please forgive me if I am breaking the rules by posting a link in your forum's. I am only doing this to help a fellow member out.
                            https://www.amazon.com/dp/B0721P1RNT/ref=cm_sw_r_em_apa_i_fx73EbT65D528
                            This is the type of fuse you will need. You can find them in lower quantities, but for $8.00 dollars, its not like they are that expensive.
                              en_passant @Karma
                              @Karma
                              Ahh, you're in the US. I did also find them - but I'm in the UK... which seems to have a distinct lack of 1A ATM mini blade fuses!
                              Might have to go with China....
                              e_p
                              • Karmaundefined
                                Karma @en_passant
                                @en_passant Hmm. Well that kinda stinks then. I will try and find it for you in the UK.
                                • Karmaundefined
                                  Karma @en_passant
                                  @en_passant Please try this link.
                                  https://www.amazon.com/dp/B07N3YP4C1/ref=cm_sw_r_cp_awdb_t1_3J73EbWQ03GP8
                                  It says they ship to UK and you can get it by this Friday
                                    Posting links is fine.
                                      en_passant @Karma
                                      @Karma
                                      Thanks for the help! Appreciated! 🙂
                                      e_p
                                      Karmaundefined 1 Reply Last reply Reply Quote 1
                                      • Karmaundefined
                                        Karma @en_passant
                                        @en_passant I am glad I was able to help soneone today. It makes the day worth living and enjoying.
                                          You can find them in the UK here https://www.co-star.co.uk/3758/mini-blade-fuse-1amp-black-pack-of-10-fbm-1-10/.
                                          They are usually available from UK eBay suppliers too, but they seem to be out of stock of the 1A version at present.
                                          en_passantundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                            en_passant @dc42
                                            Google didn't seem to pick them up for me but I've just picked them up now, thanks.
                                            e_p
