    BF Touch setup - RepRapFirmware for Duet 2 WiFi/Ethernet 3.0
    81
    • Milke
      Milke last edited by
      Hello people:
      I have one Duet2wifi 1.04 with Firmware RepRapFirmware 3.0 and operating with Duet WiFi Server Version 1.23 in my own Core XY. I'm using one BL Touch clone , the 3D Touch. sometimes the 3D Touch stop to work....
      I made a BFP Touch (Poor's man BAL) thats use a RC servo, my doubt is about the config.g and others configrations to use the BAL with this device.
      I recently changed my firmware to 3.0 and had to adjust config.g parameters differently from 2.0 firmware to use the BL Touch clone.
      I would like to know if anyone uses BAL with a servo in firmare 3.0 and if is it a possibility to share the settings for this firmware version.
        Sorry, what is BAL?
        Please update to 3.1.1, 3.0 is rather dated at this point. Please read the release notes for the intervening versions.
        Milke Steve Lynch 3 Replies Last reply Reply Quote 0
        • Milke
          Milke @Phaedrux last edited by
          @Phaedrux BAL Bed auto leveling, Im going to change my Firmware. To 3.1.1.
          • Milke
            @Phaedrux When I start to use Duet2wifi I used te BFP touch with RC servo with an older firmware, my dout is if its possible to use this configs um te mês firmware? config.g:
            M307 H7 A-1 C-1 D-1 ; Disable Heater 7
            M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
            G31 P600 X30 Y0 Z0.17 ; Set Z probe trigger value, offset and trigger height
            M557 X47:280 Y5:180 S20 ; Define mesh grid
            ; deployprobe.g
            M280 P7 S200 I1 ; Deploy probe CHECK YOUR ANGLE VALUE
            G4 P300 ; Wait 0.3 sec. (this will give enough time for the servo to extend)
            ; retractprobe.g
            M280 P7 S127 I1 ; Retract probe CHECK YOUR ANGLE VALUE
            ; homex.g
            ; called to home the X axis
            G91 ; relative positioning
            G1 Z5 F4000 S2 ; lift Z relative to current position
            G1 S1 X-300 F3600 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F3600 ; go back a few mm G1 S1 X-300 F1800 ; move slowly to X axis endstop once more (second pass)
            G1 Z-5 F4000 S2 ; lower Z again
            ; homey.g
            ; called to home the Y axis
            G1 S1 Y-180 F3600 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F4000 ; go back a few mm
            G1 S1 Y-180 F180 ; move slowly to Y axis endstop once more (second pass)
            G90 ; absolute positioning
            ; homez.g
            G0 S0 X119 Y140 F4000 ; move to center of bed
            G30 ; move Z down until the switch triggers (first pass)
            G1 Z5 F1800 ; go back a few mm
            G30 ; move Z down until the switch triggers (second pass)
            G1 Z10 F1800 S2 ; lift Z relative to current position
            ; homeall.g
            ; called to home all axes
            ;==============Home X====================
            G1 S1 X-300 F4000 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000 ; go back a few mm
            G1 S1 X-300 F180 ; move slowly to X axis endstop once more (second pass)
            ;==============Home Y====================
            G1 S1 Y-180 F4000 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F6000 ; go back a few mm
            ;==============Home Z====================
            G0 X119 Y140 F4000 ; move to center of bed
            JoergS5 1 Reply Last reply Reply Quote 0
            • JoergS5
              JoergS5 @Milke last edited by JoergS5
              @Milke you can try configuration of your solution with the instructions in
              https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
              so changing the M558 into P9 instead of P5 and M280 like in the documentation. You can test whether deployprobe and retract works by running the commands directly in the command line of the brower DWC "Send G-Code" field. You should check whether the M280 commands to set the angle values of the servo to deploy and retract are correct to move the probe out of the BFP and back into it (the S values of the M280 command in degree).
              In your homex and homey you use G1 S1, which is changed in the new firmware RRF3 version to G1 H1, documented in https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move because S is now used for Laser mode.
              Milke 1 Reply Last reply Reply Quote 1
              • Steve Lynch
                Steve Lynch @Phaedrux last edited by
                @Phaedrux, Having just gotten 3.0 set up properly, is 3.1 an easy update, or will a million things have to be re-named again?
                can it just update over 3.0 if it's already set up?
                • Milke
                  Milke @JoergS5 last edited by
                  @JoergS5 Thanks. It is similar to my BL Touch setup um RRF 3.0. Thanks, I would try
                    Yes you can probably get the clone BLTouch working using either P9 or maybe P5. YOu'll need to create the servo control pin with M950 and then reference that pin index in your M280 servo commands in the deploy and retract files.
                    @Steve-Lynch 3.1.1 is much easier than 2x to 3x. But always read the release notes for the details on what's changed.
