Acceleration test - but the result doesn't change
  • Hello,
    I tried to do an acceleration test, but the result doesn't change.
    First test I printed with no gcode modification of the part.
    Second test.
    In the gcode, I added the M201 P400 before layer=0 and every five centimeters, I updated the code with M201 P800, M201 P1200, ....
    Between test one and test two, the parts are identical like the code M201 doesn't work.
    I read in the old post, that I need to add the M400 before each M201, I tried but same result.
    I have downloaded the part from the web interface.
    I'm a beginner, I think we have a PEBCAK issue 😊
    Thanks for helping me.
    Regards.
  • @houpdelta
    You are using the wrong g-code. M201 sets per-axis (X,Y etc). P (and T) is used with M204 to set acceleration when extruding or not.
    So:
    M201 X8000 Y8000
    M204 P4000 T8000
    Would limit acceleration while extruding to 4000mm/s/s. But allow travel moves to be at 8000mm/s/s
    But:
    M201 X4000 X4000
    M204 P4000 T8000
    Would mean that travel moves would still just be 4000mm/s/s.
    Check your base M201 values and try again with M204
  • Sorry, I made a mistake in my previous post.
    I have this in my gcode.
    ;Layer:0
    M400
    M201 X3000 Y3000
    M204 P400
    ;Layer:5
    M204 P800
    ;Layer:10
    M204 P1200
    ;Layer:25
    M204 P2400.
    regards.
  • Moderator
    Does your slicer have any acceleration controls enabled? Can you share the gcode file itself?
  • @houpdelta
    Whats the acceleration on your E axis? Its possible that's the limiting factor.
  • Moderator
    Yes please share your full config.g
  • You could find the config.g
    config.g
    it has been generated by the RepRapFirmware Configuration Tool.
    I just comment the lines M201, M203, M205 to do test.
    I used Cura to generate the gcode.
    Thanks.
  • Moderator
    @houpdelta said in Acceleration test - but the result doesn't change:
    Don't do that. It's no wonder there was no change in the printed file because you've removed the definitions for all motors.
    ;M201 X3000 Y3000 Z3000 E250.00:250.00              ; set accelerations (mm/s^2)
    ;M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00    ; set maximum speeds (mm/min)
    ;M205 X900.00 Y900.00 Z12.00 E120.00:120.00         ; set maximum instantaneous speed changes (mm/min)
    Leave those in config.g. When you alter the value in the print file with M204 P T it will override the print move and travel acceleration the way you want and leave the other settings intact.
  • I just did the test on my duet 3 last night.
    I followed the same steps with the M204 after every x layers,
    BUT I also increased the global accel BEFORE the first M204 to make sure it's not limiting it.
    So the first line would be
    ; Layer = 0
    M201 X3000 Y3000
    M204 P400
  • Moderator
    Did you uncomment your speed settings in config.g?
  • @Phaedrux
    Yes I uncommented the line.
    I did tests, but at the same time I have found another problem and I have to resolve it before.
    I will post this problem in the right category.
    Regards.
