    topic_solved Problem with Duex Endstop Pins (external Gcode)
    duex5 endstop external accessories
    1
    • MauriceM
      MauriceM last edited by MauriceM
      Hello, i have a Problem with my duex Endstop pins. I want to use them as external Gcode trigger. I allready have some on the Duet and they are working fine.
      When i configure a Duex5 Endstop Pin to an Trigger for an external switch the trigger will noch be triggered when i push the switch. No matter if i invert the Pin. BUT if a cable is connected, and i pull the cable if the pin, also when it is noch attached to GROUND, the pin gets triggered....
      the problem also shows up in the newest RRF
      I dont know what causes this Problem, also the endstop pin LEDs never light up, do i have to configure them bevorhand... Or do i have a broken DUEX or DUET.
      And im currently using RRF3.0
      • MauriceM
        I solved the Problem 😄
        You have to PullUp the Pin than it will work.
