    Smart effector hotend fault 315c
    347
    • Elvis0zundefined
      Elvis0z
      My bed heater is 18c my hot end is 315c and has fault come up. Not really sure what is going on here. I have checked the wires and they seem to be in the right spot.
        What is the fault message?
        • Elvis0zundefined
          Elvis0z
          Just says fault and not to continue. It was showing 1500c on current but I had the effector wired wrong.
            Does it work properly now, with the wiring corrected and the Duet restarted?
            • Elvis0zundefined
              Elvis0z
              Hey I have a PT100 sensor that I got with my effector. I'm a bit confused about how to plug this in. Seems I need another board to use it, is that right. I'm still getting fault I just moved the 2 wires that go from T1 and T2 to T2 and T3 on the 8 pin molex plug on top of the effector.
                To use a PT100 with a Duet, you need one of these https://www.duet3d.com/DuetAddons/PT100_DaughterBoard. A PT1000 (note the extra zero) does not need one.
                • Elvis0zundefined
                  Elvis0z
                  Ahhh so would that be why I'm getting the heater error on T0.
                    Yes, a PT100 connected to a thermistor input will read a high temperature.
                    Elvis0zundefined 1 Reply Last reply Reply Quote 0
                    • Elvis0zundefined
                      Elvis0z
                      Cool thanks for your help. Problem solved woohoo
                      • Elvis0zundefined
                        Elvis0z @dc42
                        @dc42 Just put another sensor in to see what happened and I get this error
                        M305 P1 x200
                        Failed to initialise RTD bad response from the sensor.
                        Elvis0zundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • Elvis0zundefined
                          Elvis0z @Elvis0z
                          @Elvis0z Just refreshed the web GUI and no error now the temp on the hot end is 12c
                            Phaedrux Moderator @Elvis0z
                            @Elvis0z said in Smart effector hotend fault 315c:
                            M305 P1 x200
                            If you change the sensor to a thermistor you'll need to change the configuration as well. M305 P1 x200 is for a PT100.
