UNSOLVED Formbot Troodon RRF 3.1.1 Update
  • Im trying to get the Formbot Troodon updated to 3.1.1 and running into an odd issue. Firstoff, this is a custom compatible board. Its essentially a Duet2Wifi and Duex5 in a single PCB with bigfoot format 2660 removable drivers.
    The machine works as intended on 3.0.0. Config is here :
    https://github.com/InsanityAutomation/FormbotTroodon/blob/master/sys/config.g
    3.0.1 RC11 and 3.1.1 Release both exhibit the same issue. Any motion command to any stepper gets the following response :
    M997 S1
    Warning: motor phase A may be disconnected reported by driver(s) 0 1
    Warning: motor phase B may be disconnected reported by driver(s) 0 1
    I tried changing to a new stepper motor to be sure with no dice. Rolling back to 3.0.0 everything works as intended.
    I attempted to modify the current values from 1200 down to 1000 and up to 1300 with no change.
    Anyone have any ideas of something to try? Is there some other change between these versions im missing from the release notes?
    Thanks
  • From my own experience, this happens if you have a loose crimp on the cabling. I suggest you check crimps first, solder points second.
  • @oliof It's worth noting if I load 3.0.0 back to it, everything works smoothly again. No physical change between when it works and then doesn't on 3.1.1.
  • Interesting. I upgraded from 3.0-RC4 to 3.1.1 just the other day and (on a Duet3) board this worked just fine. So I guess this is one for the experts and not an innocent bystander (-:
  • Moderator
    So the config.g is the same, and only the firmware version is changing?
    Can you send M98 Pconfig.g in the gcode console and see what errors if any are reported?
    Can you also send M122 and report the result.
  • Thats correct, no changes other than bringing the firmware bin file back and forth.
    With 3.0.0 Installed :
    M98 Pconfig.g
    Error: M574: endstop type 0 is no longer supported. Use type 1 and invert the input pin instead.
    HTTP is enabled on port 80
    FTP is disabled
    TELNET is disabled
    Error: M307: Heater 3 not found
    Warning: M307: heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 542C.
    Error: M106: Fan number 3 not found
    Error: M106: Fan number 4 not found
    Error: M106: Fan number 5 not found
    Error: M106: Fan number 6 not found
    Error: M106: Fan number 7 not found
    Error: M106: Fan number 8 not found
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DJM-9178L-L4MSJ-6J9FG-3S86S-982QP
    Used output buffers: 3 of 24 (10 max)
    Static ram: 30516
    Dynamic ram: 92392 of which 60 recycled
    Exception stack ram used: 504
    Never used ram: 7600
    Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,3676) IDLE(ready,156)
    Owned mutexes:
    Last reset 45:02:35 ago, cause: software
    Last software reset at 2020-05-04 22:19, reason: User, spinning module GCodes, available RAM 7356 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 24.5, current 26.7, max 27.8
    Supply voltage: min 23.8, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/223
    Driver 2: temperature-shutdown! short-to-ground standstill, SG min/max not available
    Driver 4: temperature-shutdown! short-to-ground standstill, SG min/max not available
    Driver 5: standstill, SG min/max 0/244
    Driver 6: standstill, SG min/max 0/242
    Driver 7: standstill, SG min/max 0/234
    Driver 8: standstill, SG min/max 0/241
    Driver 9: temperature-shutdown! short-to-ground standstill, SG min/max not available
    Date/time: 2020-06-16 09:59:35
    Slowest loop: 77.99ms; fastest: 0.09ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 27507ms
    === MainDDARing ===
    Scheduled moves: 11, completed moves: 11, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.49ms; fastest: 0.00ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    WiFi firmware version 1.23
    WiFi MAC address 2c:f4:32:58:8a:07
    WiFi Vcc 3.38, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 23992
    WiFi IP address 172.16.0.213
    WiFi signal strength -58dBm, reconnections 0, sleep mode modem
    === Filament sensors ===
    Extruder 0 sensor: no filament
    And with 3.1.1
    M98 Pconfig.g
    Error: endstop type 0 is no longer supported. Use type 1 and invert the input pin instead.
    FTP is disabled
    TELNET is disabled
    Error: Heater 3 not found
    Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 542C
    Error: Fan number 3 not found
    Error: Fan number 4 not found
    Error: Fan number 5 not found
    Error: Fan number 6 not found
    Error: Fan number 7 not found
    Error: Fan number 8 not found
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
    Used output buffers: 3 of 24 (12 max)
    Static ram: 27980
    Dynamic ram: 94372 of which 100 recycled
    Exception stack ram used: 264
    Never used ram: 8356
    Tasks: NETWORK(ready,392) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1552) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:57 ago, cause: software
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 25.9, current 26.6, max 26.9
    Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Date/time: 2020-06-16 10:02:11
    Cache data hit count 57130340
    Slowest loop: 78.89ms; fastest: 0.62ms
    === Storage ===
    SD card longest read time 3.0ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    === Network ===
    Slowest loop: 20.11ms; fastest: 0.00ms
    - WiFi -
    Network state is active
    WiFi Vcc 3.38, reset reason Unknown
    WiFi flash size 4194304, free heap 24160
    WiFi signal strength -54dBm, reconnections 0, sleep mode modem
    === DueX ===
    Read count 1, 1.04 reads/min
  • Also worth noting the 3 drivers listing error states (2,4, and 9) do not physically exist on this board.
    Thanks
  • Moderator
    well they have a few errors for a RRF3 config, but nothing that I can see would cause issues...
    M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
    You can remove that line to stop the M574 type 0 not supported error
    M307 H3 A-1 C-1 D-1 ; set PID tuned settings for heater 0
    You can remove that line to stop the heater 3 not found error
    M140H0 There should be a space between M140 and H0
    ; --- Set or report heating process parameters---
    M106 P3 I-1
    M106 P4 I-1
    M106 P5 I-1
    M106 P6 I-1
    M106 P7 I-1
    M106 P8 I-1
    I'm not sure what their intention is for this block, but inverting the pin is done with M950 in RRF3. I'd just remove those lines. that's the fan not found errors.
    M569 P2 R-1
    M569 P4 R-1
    M569 P9 R-1
    These lines should function to stop monitoring those missing drivers you mention, but they don't seem to be working in 3.1.1. I'm not sure what has changed.
    Can you try sending them again in the console?
    What do you get if you send M569 by itself?
  • Those do function to stop the flood of warnings that were present before adding them. The command goes green in the terminal after sending on DWC with no error reported. No change in M122 output.
    If my memory is correct, the M574 command was included in the 3.0 documentation on setting up the BLTouch to release the z endstop pin. Is there another line required to do the same thing with 3.1.1 or is it unassigned by default?
  • Moderator
    @InsanityAutomation said in Formbot Troodon RRF 3.1.1 Update:
    Exactly. In order to be more generic there are no more assumed assignments. Instead you use M950 to define the pins you are using. In your case for the BLTouch that would be M950 S0 C"duex.pwm5"
    Sorry for M569 you'll need to specify the driver number as well so try sending M569 P2
  • M569 P2
    Drive 2 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 127
  • Seems akismet wants to flag it as spam for some reason... lol Im adding a bit more content above it to try and get rid of that warning....
    M569 P0
    Drive 0 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P1
    Drive 1 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P2
    Drive 2 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 63
    M569 P3
    Drive 3 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P4
    Drive 4 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 63
    M569 P5
    Drive 5 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P6
    Drive 6 runs in reverse, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P7
    Drive 7 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P8
    Drive 8 runs in reverse, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 0
    M569 P9
    Drive 9 runs forwards, active low enable, step timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos 63
  • Moderator
    so are you still getting the errors when trying to move the axis after you've sent:
    M569 P2 R-1
    M569 P4 R-1
    M569 P9 R-1
  • @Phaedrux said in Formbot Troodon RRF 3.1.1 Update:
    M569 P4 R-1
    Yup, no change in function or output sending those manually.
  • Moderator
    Alright. I'm not sure what changed between 3.0 and 3.1.1 that would explain this. You'll have to hold tight until @dc42 has a chance to take a look. It is likely related in some way to the odd combo board being used.
  • Id assume so as well. When I showed Tony the board at ERRF last year he was glad to see something not a direct clone for a change but here is the risk of it not being a direct clone lol
  • Moderator
    Yes it's definitely an interesting beast. Do you have any other info on it? I wasn't able to get much from googling.
  • I can grab some photos of it when I get home (Remote VPN for last testing bits!) Personally I really like the removable drivers despite the thermal constraints as they are still one of the most failure prone components on these boards. People who (ab)use machines like I do tend to go through a few of em....
  • Figured I'd bump this and see if anyone had any other idea before i dig into source myself.
  • I have exactely the same issue on my Troodon, but I'm using a different (self made) config.g file. So i'm back on 3.0 for now. And I do have a newer board which is black.
  • Moderator
    @Guzzi Does Troodon give any firmware guidance with regards to the custom board?
  • From what I can tell, the stock firmware for the Troodon isn't even available for download anywhere. The firmware for their other machines is provided via zip files hosted on a variety of file hosts (some on drop box, some on google drive, etc).
    Also, Vivedino/Formbot appears to be a very small company. It looks like their entire lineup aside from the Troodon uses the same marlin motherboard.
    All of this combined makes me think that perhaps a 3rd party designs boards for them. If that's the case then they may not even have someone who could provide help with firmware.
  • @Phaedrux no they only provide the firmware which the machine is shipped with. So 2.03RC3. I asked them if they already have a config for 3.0. They told me that if I wan't to upgrade I have to write my own. So that's what I did but unfortunately had the fault issue on 3.1.1.
