    Proximity Sensor PL-08N
    Firmware installation
    • mrenz999
      mrenz999 last edited by
      Ok I have this installed on io3. The first 3 pegs as it is a 5v. So that's 5v power, out, and ground. Selected simple IR probe in firmware configurator. It detects the bed when it is close. Light comes on. Turns off when it moves away. Webcontrol does not detect it triggering.
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 08:19:17 GMT-0700 (Pacific Daylight Time)
      M550 P"Duet 3" ; set printer name
      M669 K1 ; select CoreXY mode
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; set axis maxima
      M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P2 C"io3.in+io3.out" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X20 Y0 Z4 ; set Z probe trigger value, offset and trigger height
      M557 X30:260 Y20:260 S20 ; define mesh grid
      M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
      M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
      M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      M501
      Lol went
      • jay_s_uk
        jay_s_uk last edited by
        Why have you got it connect to out when it is an input?
        mrenz999 1 Reply Last reply Reply Quote 0
        • mrenz999
          Good question. I will switch that.
          • mrenz999
            mrenz999 @jay_s_uk last edited by
            @jay_s_uk Ok I switched that and still it isn't recognizing any change in webcontrol when it detects
            • jay_s_uk
              @mrenz999 said in Proximity Sensor PL-08N:
              have you changed the above line to be just io3.in?
