    Duet 3 RRF3 First wireup :)
    • mrenz999undefined
      mrenz999
      2 questions. Do I need an SD card in the Duet 3 with the PI connected ?
      And should the Red Diag light be illuminated ?
      • HebigTundefined
        HebigT
        1). You'll want to remove the SD card when running in SBC mode (with Pi connected)
        Since the SD card normally holds your printer config files, they will be placed in a directory on the Pi instead.
        2). When running in SBC mode, the Red diag LED will blink every second.
        Here's a good resource if you haven't already seen it:
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
        mrenz999undefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User @mrenz999
          No, should not have a SD card or ethernet connected to Duet 3 when using with raspberry pi.
          Diag should blink if firmware is running normally afaik
          • mrenz999undefined
            mrenz999 @HebigT
            @jpomo10 Thank you. Blinking every second is about right 🙂 Now to get the IR sensor working so I can home things 🙂
