    Thermistor's shows 2000°C ( Slolved )
    64
    • thomasthetrain
      thomasthetrain last edited by thomasthetrain
      So I recently bought a duet wifi. I've conected it all and it's working, except for the heating.
      When I start my duet it's all normal.(except for the 2000°C)
      But when I try to heat up my Nozzel / Bed it goes to active and then fault,
      it also shows an error message.
      Error: Temperature reading fault on heater 1: unknown temperature sensor channel
      I've seen some posts tackling this but none of them are helping me, or im just a dummy.
      I've mesured the thermistors at the conector they both show 100k.
      I've mesured the vssa fuse, endstop ground to thermistor vssa 0.6 Ohm.
      and I've checked the config file but I can't find anything wrong.
      My hotend heater/thermistor are conected on E0 heat / E0 temp
      and the bed to bed heat / bed temp.
      (I did notice that my bed thermistor wire had a bit exposed wire on it, but should I get 0.6 ohm
      if it had blown the vssa fuse ?)
      What can I do ? 😞
      config file below
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 15 2020 19:23:57 GMT+0200 (centraleuropeisk sommartid)
      M550 P"JgAurora A5s" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z1066.67 E409.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z120.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X180000.00 Y180000.00 Z180.00 E7200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z50.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X265 Y280 Z300 S0 ; set axis maxima
      M574 X1 S0 P"xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S0 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S0 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Cooling Fan 1" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 S"Hemera" D0 H1 F0 ; define tool 0
        Please verify what firmware version you have installed using M115 in the gcode console.
        Also send M98 Pconfig.g and report back with any errors.
        • giostark
          giostark last edited by giostark
          Phaedrux is far more competent but I try to be helpful.
          The bed Heater section seems fine,
          In most cases I have seen here in this forum (if the thermistor is good), the principal culprit is bad wiring. Me too I experienced this and was bad wiring. If you just detach the nozzle thermistor you can see 2000 there also. If you plug it back , it turn normal.
          I would try a cross test. You need a different thermistor for the bed to try.
          Maybe you could use the nozzle thermistor on the bed channel for see if wiring are ok (of course without heat anything!). Numbers will be wrong but at least you know if there is a stable connection.
          thomasthetrain 1 Reply Last reply Reply Quote 0
          • thomasthetrain
            The M115 response:
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
            and the M98:
            M98 PCONFIG.G
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Warning: M308 command is not supported
            Warning: M950 command is not supported
            • deckingman
              deckingman @thomasthetrain last edited by
              @thomasthetrain That'll be it then. You are using version 2 firmware but your configuration file is for version 3 firmware. You need to change one or the other. If you are new to Duet, then the easiest path might be to use the online configuration tool to generate new configuration files but select the correct tool.
              • thomasthetrain
                thomasthetrain @giostark last edited by
                @giostark I have tryed to conect 100K resistors directly to the thermistor conector
                on on my duet and it behaves exactly the same
                • deckingman
                  @thomasthetrain See my post above. When you use the configuration tool, under "Firmware version" there is a drop down list. Select "2.03 to 2.05" in that list.
                  • giostark
                    This post is deleted!
                    • giostark
                      Ok Thomas.
                      Deck is right , you are using the v2 firmware with v3 settings.
                      For upgrade the firmware from 2 to 3 you have to make before 2.xx.x>3.0 then 3.0>3.1.1
                      If you have the panel due don't forghet to add this line on top :
                      M575 P1 S1 B57600; enable panel due to connect properly
                      Here all the info:
                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
                      ps:
                      damn ctrl+shift+enter had tripled the post...
                      • giostark
                        • thomasthetrain
                          THANX everybody its all good now ❤
