    3DTouch configuration not working
    529
    • Nemesis1782undefined
      Nemesis1782
      Hi all,
      I'm having issues getting the 3dtouch probe to do anything on my new printer (https://forum.duet3d.com/topic/15550/3davii?_=1592476055256).
      The symptoms:
      When starting the printer the 3DTouch does it's usual startup routine (down,up,down,up). After which it settles in the up position with the red light continuously on (if I remember correctly that is what is supposed to happen). So all seems well, however as soon as I try to deploy the probe in any for nothing happens. I do not get a Duet error nor does the probe go into the blinking alarm state.
      One other weird thing I noticed is that when the duet starts it tells me in the webinterface that the probe is measuring -1000, however the whole probe indicator dissapears from the web interface within a matter of seconds.
      Any help would be greatly appreciated. If any additional information is needed please let me know.
      I am using a duetwifi2 and duex 2 with RRF3 and the new web gui
      The 3DTouch I am using: https://nl.aliexpress.com/item/32958675206.html?src=google&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Gploogle_7_shopping&aff_atform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=6459980570&albag=76980386066&trgt=743612850714&crea=nl32958675206&netw=u&device=c&albpg=743612850714&albpd=nl32958675206&gclid=Cj0KCQjwoaz3BRDnARIsAF1RfLeL6LJvrGyyVg08edGCaS-twLaIrZcKKIKt-2n2DzhLqUQ6YRUGQsUaAn5jEALw_wcB&gclsrc=aw.ds
      Connections:
      The 3dTouch sensor part is connected to the duetwifi zbed sensor connector, the actuator side is connected to the Duex2 PWM5.
      Configuration (as generated by reprap configurator):
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X20:200 Y20:200 S40 ; define mesh grid
      Deploy Probe script:
      M280 P7 S10 ; deploy BLTouch
      Retract Probe script:
      M280 P7 S90 ; retract BLTouch
        Phaedrux Moderator @Nemesis1782
        @Nemesis1782 said in 3DTouch configuration not working:
        RRF3
        If you are using RRF3 your config is incorrect.
        Please send M115 to verify your installed firmware version and send M98 Pconfig.g and report back with any error messages you get.
        If you are using RRF 3.1.1 you'll need to modify your config to match. It will likely be easiest to use the web configurator to generate a new config compatible with RRF3.
        https://configtool.reprapfirmware.org/Start
          Nemesis1782
          Erm. Yeah you're right no idea how I missed that... I fixed that right away. However it still does not work. Tomorrow I'll double check everything and report back!
          The M98 is handy thnx did not know that existed.
          Firmware reports: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC4 ELECTRONICS: Duet WiFi 1.02 or later + DueX2 FIRMWARE_DATE: 2020-03-16b1
          The config for Bedlevel is now:
          M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
          M557 X15:215 Y15:195 S20 ; define mesh grid
          The M98 reported, heater warnings are as expected since I have not configured my tools yet:
          6/18/2020, 8:33:16 PM M98 PCONFIG.G
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          6/18/2020, 8:33:16 PM Warning: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
          Warning: heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 973C.
          Error: Heater 2 not found
          Error: Heater 3 not found
          Error: Heater 4 not found
          Error: Heater 5 not found
          Error: Heater 6 not found
          Error: Heater 7 not found
            Please update to 3.1.1
            Nemesis1782undefined 1 Reply Last reply Reply Quote 0
              Nemesis1782 @Phaedrux
              @Phaedrux updated a quick test still gets me the same result. I'll double check everything later today.
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later + DueX2 FIRMWARE_DATE: 2020-05-19b2
              Edit: the Z probe now shows in the web interface though 🙂
              Edit2: I found a M307 for Heater 7 (PWM 5) in the config-override.g, however I do remember reading the Duet holding on to old config. How do I make sure the duet forgets about the old config?
                Please post your current config.g, config-override.g, deployprobe.g, retractprobe.g, and homeall.g/homez.g
                Are you still plugging into the Duex? Which port again?
                Nemesis1782undefined 3 Replies Last reply Reply Quote 0
                  @Phaedrux Hi Phaedrux, thnx for your time as always.
                  Yes I am using the Duex2 port pmw5. I have only included the homez.g, homeall.g is not right. Do keep in mind that I am not homing I'm just trying to get the probe itself to move. Onze that works the rest should not be a problem.
                  Config.g:
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 09 2020 12:23:53 GMT+0200 (Midden-Europese zomertijd)
                  M550 P"3DavII" ; set printer name
                  M669 K1 ; select CoreXY mode
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P2 S0 ; physical drive 2(X) goes backwards
                  M569 P1 S0 ; physical drive 1(Y) goes backwards
                  M569 P0 S0 ; physical drive 0 goes forwards
                  M569 P3 S0 ; physical drive 3 goes forwards
                  M569 P4 S0 ; physical drive 4 goes forwards
                  ;M584 X2 Y1 Z0:3:4 U3 V4 P3 ; Set the drive mapping, the Duet drivers are numberred (Z)2,(Y)1,(X)0,(E1)3,(E2)4
                  M584 X2 Y1 Z0:3:4 ; Set the drive mapping, the Duet drivers are numberred (Z)2,(Y)1,(X)0,(E1)3,(E2)4
                  M350 X16 Y16 Z16:16:16 I1 ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z1280.00:1280.00:1280.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00:12.00:12.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z1800.00:1800.00:1800.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00:20.00:20.00 ; set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z1700:1700:1700 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X575 Y560 Z580 S0 ; set axis maxima
                  M574 X0 S1 P"zstop" ; configure active-low endstop for low end on X via pin !zstop
                  M574 Y0 S1 P"ystop" ; configure active-low endstop for low end on Y via pin !ystop
                  M574 Z1 S1 P"!xstop+!e0stop+!e1stop" ; configure active-low endstop for low end on Z via pin !xstop
                  Config-overide.g:
                  ; Heater model parameters
                  M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                  M307 H1 A948.0 C252.3 D6.0 S1.00 V12.2 B0
                  ;M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ;M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ;M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ;M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ;M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  ;M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                  Deployprobe.g:
                  M280 P7 S10 I1
                  Retractprobe.g:
                  M280 P7 S90 I1
                  Homez.g:
                  G91 ; relative positioning
                  G1 H1 Z6000 F1800 ; move Z down until the endstop is triggered
                  G92 Z580 ; set Z position to axis minimum (you may want to adjust this)
                    @Phaedrux I was checking the documentation and noticed that the duex2 under version 0.8b does not support PWM 4 and 5. How do I check which version the board is?
                    Edit: Just checked and it is version 0.8. I'll move it to PWM3 later today.
                      @Phaedrux Alright so I am doing something seriously wrong. It is not behaving as I expect.
                      I've moved the connector to Duex PWM3 and changed the config. When I start the printer the Touch goes into error blue on blinking red.
                      When I then plug the Touch back into PWM5 and start the printer it does the correct startup procedure even though the config is pointing to PWM3.
                      config.g:
                      M950 S0 C"duex.pwm3" ; create servo pin 0 for BLTouch
                      config-overide.g not changed.
                      Deploy and retract changed P7 to P5
                        Deployprobe.g:
                        M280 P7 S10 I1
                        Retractprobe.g:
                        M280 P7 S90 I1
                        When using the Duex you must remove the I1 from those commands.
                        And when using RRF3 you must change the P number to match the index of the servo pin you created, so M950 S0 C"duex.pwm3" is servo #0, so your deploy and retract should be
                        Deployprobe.g:
                        M280 P0 S10
                        Retractprobe.g:
                        M280 P0 S90
                        Your home Z is using an endstop move, you'l need to change that to use G30 to use the probe.
                        Nemesis1782undefined 2 Replies Last reply Reply Quote 0
                          @Phaedrux said in 3DTouch configuration not working:
                          M280
                          Ah Yeah. Saw it in the documentation. I just assumed that hadn't changed for RRF3. Thnx
                          @HomeZ, yeah that is by design. I have 3 independent Z axis drivers and first home it to the end stop to make sure it's straight after which I'll fine tune using the bed level sensor.
                            @Phaedrux Hi, I've resolved it. It turns out one of the wires on the connector wasn't making a connection 😧
                            Sorry for wasting your time and thnx for your help and patience! 👍
                            Edit: So I tried going back to PWM5 since that's the one I would like to use and that is indeed not working. (well only on startup for some reason). Not a big issue thouh. However I would've liked to have the bed level sensor plugged into the most left PWM.
