    BL-Touch - Voltage?
    • duttiundefined
      dutti
      hey,
      the configuration tool tells me that I have to switch from 5v to 3.3v concerning the BL-Touch. What do I have to switch and how to do it?
      And do I have to wire only to 4 pins on deut3 6hc?
      thanks a lot
      arhiundefined 1 Reply Last reply Reply Quote 0
      • arhiundefined
        arhi @dutti
        @barbarossa-cologne
        • voltage depends on the version of bltouch, newest ones are working either way, older ones you need to cut one trace and oldest ones do not work on 3V
        • wires - bltouch comes with 2xgnd so you need to connect only one, the other one is not required. So min is Vcc, Vss, Servo, Signal.
        • duttiundefined
          dutti
          @arhi
          thank you!!
            Duet 3 is 5V tolerant, so even if using an old version of BLTouch it does not need to be set to 3.3V.
