SOLVED Paneldue 7i not working (USB or 4 pin)
I ordered a Duet 2 wifi and Paneldue 7i from E3D, got the main board up and running and works perfectly well.
However, I can not get any sign of life from the Paneldue at all, I initially tried the USB connector (with nothing else plugged in) to update the firmware, but the computer did not recognise anything was plugged in. Secondly, I tried connecting through the supplied 4 pin connector, and again, no sign of life.I do get 5V at the 4 pin connector.
All appropriate precautions were taken before plugging in the board.I tried claiming a refund through E3D, but I need an admin from this forum to confirm it is a warranty issue me I should go that route. I can do any trouble shooting with a multimeter if needed.
Thanks in advance!
see if you can update the firmware according to https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
(try another usb cable and/or usb port if you have trouble getting the serial port to show up on the computer)
@bearer said in Paneldue 7i not working (USB or 4 pin):
I've tried all these, thanks for your suggestions though!
Does the backlight illuminate when connecting via USB?
@Phaedrux There is no backlight at all via USB nor 4pin.
@Sten said in Paneldue 7i not working (USB or 4 pin):
Sounds like the backlight driver has failed. I approve this for warranty replacement. Please contact E3D and follow their warranty process, referring to this thread for approval. Apologies for the inconvenience.
Edit: Actually, rereading this, it sounds even more fundamental than the backlight driver failing, perhaps the voltage regulator. Still a warranty replacement!
@droftarts Thank you.
@droftarts It has now been 9 days since I emailed E3D the details they require for the warranty claim. And no response, first point of contact took less than half a day for a response.. I'm not sure what to do at this point..
@Sten Perhaps send a follow up email to inquire.
