    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    33.2k
    • smoki3undefined
      smoki3 @A Former User
      @bearer but the have to be two as far I got it right
      • wilrikerundefined
        wilriker @smoki3
        @smoki3 The second file http.json is for the DWS (Duet Web Server) not relevant for the problem here.
        This is a shot in the dark but please try adding
        # Fix core frequency to have constant SPI clock speed
        core_freq=250
        core_freq_min=250
        to your /boot/config.txt and reboot the RPi. It might be that Duet 2 does not like RPi's default SPI frequency shenanigans (neither do I 😂 )
        Manuel
        My Tool Collection
        smoki3undefined 1 Reply Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @wilriker
          @wilriker said in Duet 2 Ethernet and SBC:
          core_freq=250
          core_freq_min=250
          So this doesn't help. Same behaviour as before
          It wired because it only happens while homing.
          • smoki3undefined
            smoki3
            If I try to flash the firmware over DWC I also get checksum error
            ed
            [warn] Bad header checksum (expected 0x40cc, got 0xe30e)
            [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000004)
            [warn] Bad header checksum (expected 0xc340, got 0xa71d)
            [warn] Bad header checksum (expected 0x40cc, got 0xcdbd)
            [warn] Restarting transfer because the number of maximum retries has been exceeded
            [warn] Bad header checksum (expected 0x0040, got 0x5620)
            [warn] Note: RepRapFirmware didn't receive valid data either (code 0x0002005f)
            [warn] Bad header checksum (expected 0x0000, got 0x4260)
            [info] Flashing RepRapFirmware
            [info] Verifying checksum
            [error] Firmware checksum verification failed
            [error] Could not flash the firmware binary after 3 attempts. Please install it manually via bossac.
            [warn] Bad header checksum (expected 0x80ac, got 0xbe3b)
            [info] Application has shut down
            • A Former User?
              A Former User
              how long is the cable used, and what type of cable is it?
              • smoki3undefined
                @bearer it's a normal ribbon cable with a length of 8cm
                • A Former User?
                  A Former User @smoki3
                  @smoki3 said in Duet 2 Ethernet and SBC:
                  8cm
                  should be okay, still try lowering "SpiFrequency": 8000000, to say 2000000 in /opt/dsf/conf/config.json and restart DCS (sudo systemctl restart duetcontrolserver) ?
                  • wilrikerundefined
                    wilriker
                    IAP is fixed now also on master branch.
                    Manuel
                    My Tool Collection
                    • A Former User?
                      A Former User @wilriker
                      btw i think there was a slight hickup with it refusing M997 S0 - but can't reproduce it after it did update with both DWC asking to update and M997 without S0.
                      • wilrikerundefined
                        wilriker @A Former User
                        @bearer Since there is only one type of firmware to update it is unnecessary to provide a Snnn parameter to M997 in the first place but I agree that it should not result in either a warning or worse an error. If you can reproduce it, please post here.
                        Manuel
                        My Tool Collection
                        • wilrikerundefined
                          wilriker @smoki3
                          If everything is working as expected you should not get any checksum errors at all. If you get them more than once something is still wrong.
                          Have you made sure that both the Duet 2 and the Raspberry Pi share a common ground connection?
                          Manuel
                          My Tool Collection
                          • smoki3undefined
                            @bearer said in Duet 2 Ethernet and SBC:
                            8000000
                            This doesn't help
                            • smoki3undefined
                              smoki3 @wilriker
                              Yes both are connected directly to ground
                              • smoki3undefined
                                smoki3
                                I tried now different cables, direct wiring without PCB and 470ohm resistors.
                                But always the same issue.
                                Also tried now without resistors, same issue
                                • A Former User?
                                  A Former User @T3P3Tony
                                  @T3P3Tony said in Duet 2 Ethernet and SBC:
                                  We are considering a small hardware board to provide the physical interfacing and signal buffering.
                                  if the series resistance is deemed all that is needed, then a few crimps and a printed part goes a long way:
                                  Btw, is there a part# for the nylon stand offs? gonna try a pogo-pin version for the Wifi
                                  • gtj0undefined
                                    gtj0
                                    Jeez. I take some time off and this happens. 🙂
                                    • smoki3undefined
                                      smoki3
                                      @wilriker
                                      Today I am back from holidays. I tried to investigate a bit more but it does not help. I disassembled the Duet 2 Ethernet from my printer so I have no other cables in the near of the board. I also made a new cable out of a shielded ethernet cable to avoid any EMC troubles. But still the same. If I try to flash the firmware for example I get many checksum errors.
                                      @bearer
                                      are you now able to flash the firmware over DWC? I always get checksum error.
                                      • A Former User?
                                        with both the Wifi and Ethernet (Duets) yes
                                        • smoki3undefined
                                          @bearer so I mean with the SBC connected
                                          Which raspberry do you use?
                                          • A Former User?
                                            A Former User
                                            yes yes, update wifi and ethernet boards with RRF3.2 over SPI from the SBC, Once I shortened the wires and had my novice crimp the resistors instead of trying to solder its all good at 8Mhz.
                                            edit: one 4B 4GB, 3B+ and some 2B tested.
