    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.2k
    • wilrikerundefined
      wilriker @smoki3
      @smoki3 The second file http.json is for the DWS (Duet Web Server) not relevant for the problem here.
      This is a shot in the dark but please try adding
      # Fix core frequency to have constant SPI clock speed
      core_freq=250
      core_freq_min=250
      to your /boot/config.txt and reboot the RPi. It might be that Duet 2 does not like RPi's default SPI frequency shenanigans (neither do I 😂 )
      Manuel
      My Tool Collection
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • smoki3undefined
        smoki3 @wilriker
        @wilriker said in Duet 2 Ethernet and SBC:
        core_freq=250
        core_freq_min=250
        So this doesn't help. Same behaviour as before
        It wired because it only happens while homing.
        • smoki3undefined
          smoki3
          If I try to flash the firmware over DWC I also get checksum error
          ed
          [warn] Bad header checksum (expected 0x40cc, got 0xe30e)
          [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000004)
          [warn] Bad header checksum (expected 0xc340, got 0xa71d)
          [warn] Bad header checksum (expected 0x40cc, got 0xcdbd)
          [warn] Restarting transfer because the number of maximum retries has been exceeded
          [warn] Bad header checksum (expected 0x0040, got 0x5620)
          [warn] Note: RepRapFirmware didn't receive valid data either (code 0x0002005f)
          [warn] Bad header checksum (expected 0x0000, got 0x4260)
          [info] Flashing RepRapFirmware
          [info] Verifying checksum
          [error] Firmware checksum verification failed
          [error] Could not flash the firmware binary after 3 attempts. Please install it manually via bossac.
          [warn] Bad header checksum (expected 0x80ac, got 0xbe3b)
          [info] Application has shut down
          • A Former User?
            A Former User
            how long is the cable used, and what type of cable is it?
            • smoki3undefined
              smoki3 @A Former User
              @bearer it's a normal ribbon cable with a length of 8cm
              • A Former User?
                A Former User @smoki3
                @smoki3 said in Duet 2 Ethernet and SBC:
                8cm
                should be okay, still try lowering "SpiFrequency": 8000000, to say 2000000 in /opt/dsf/conf/config.json and restart DCS (sudo systemctl restart duetcontrolserver) ?
                • wilrikerundefined
                  wilriker
                  IAP is fixed now also on master branch.
                  Manuel
                  My Tool Collection
                  • A Former User?
                    A Former User @wilriker
                    btw i think there was a slight hickup with it refusing M997 S0 - but can't reproduce it after it did update with both DWC asking to update and M997 without S0.
                    • wilrikerundefined
                      wilriker @A Former User
                      @bearer Since there is only one type of firmware to update it is unnecessary to provide a Snnn parameter to M997 in the first place but I agree that it should not result in either a warning or worse an error. If you can reproduce it, please post here.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker @smoki3
                        If everything is working as expected you should not get any checksum errors at all. If you get them more than once something is still wrong.
                        Have you made sure that both the Duet 2 and the Raspberry Pi share a common ground connection?
                        Manuel
                        My Tool Collection
                        • smoki3undefined
                          @bearer said in Duet 2 Ethernet and SBC:
                          8000000
                          This doesn't help
                          • smoki3undefined
                            smoki3 @wilriker
                            Yes both are connected directly to ground
                            • smoki3undefined
                              smoki3
                              I tried now different cables, direct wiring without PCB and 470ohm resistors.
                              But always the same issue.
                              Also tried now without resistors, same issue
                              • A Former User?
                                A Former User @T3P3Tony
                                @T3P3Tony said in Duet 2 Ethernet and SBC:
                                We are considering a small hardware board to provide the physical interfacing and signal buffering.
                                if the series resistance is deemed all that is needed, then a few crimps and a printed part goes a long way:
                                Btw, is there a part# for the nylon stand offs? gonna try a pogo-pin version for the Wifi
                                • gtj0undefined
                                  gtj0
                                  Jeez. I take some time off and this happens. 🙂
                                  • smoki3undefined
                                    smoki3
                                    @wilriker
                                    Today I am back from holidays. I tried to investigate a bit more but it does not help. I disassembled the Duet 2 Ethernet from my printer so I have no other cables in the near of the board. I also made a new cable out of a shielded ethernet cable to avoid any EMC troubles. But still the same. If I try to flash the firmware for example I get many checksum errors.
                                    @bearer
                                    are you now able to flash the firmware over DWC? I always get checksum error.
                                    • A Former User?
                                      with both the Wifi and Ethernet (Duets) yes
                                      • smoki3undefined
                                        @bearer so I mean with the SBC connected
                                        Which raspberry do you use?
                                        • A Former User?
                                          A Former User
                                          yes yes, update wifi and ethernet boards with RRF3.2 over SPI from the SBC, Once I shortened the wires and had my novice crimp the resistors instead of trying to solder its all good at 8Mhz.
                                          edit: one 4B 4GB, 3B+ and some 2B tested.
                                          • smoki3undefined
                                            @bearer How short are your cables?
