    Duet 2 WiFi not working
    Firmware installation
    661
    • Jesterizeundefined
      Jesterize
      I upgraded the firmware on both the Duet 2 and the WiFi, but the WiFi keeps coming back with "WiFi module is being started" in YAT with 552 command. These are the steps I have run:
      • Ran M115 to check that the latest firmware is installed.
      • Ran M997 S1 to install the DuetWiFiFirmware.bin file.
      • Ran M552 S0 to put the WiFi module in idle mode
      • Run M552 to check that it is in idle mode but it is still "being started"
      • Ran M587 to add the SSID and password, but it comes back with "M587: Failed to add SSID to remembered list"
      I have tried reverting back to an older firmware version and wifi version. Same exact thing.
      Anything else I should be trying?
        Is this a new board?
          Jesterize
          Newish. From December.
            Was it ever working?
            What firmware version was on before?
            Does the wifi firmware version install?
            Can you provide the results of a M122?
              Jesterize
              • No it was never working. Just got it installed last night.
              • Not certain. Jumped to 3.1.1. Then, reverted back to 2.05.1
              • Again, not certain.
              • As soon as I get home, I will post the results of an M122
                Jesterize
                M122 results
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3SD6J-KUMHF
                Used output buffers: 1 of 24 (10 max)
                Static ram: 25712
                Dynamic ram: 92704 of which 0 recycled
                Exception stack ram used: 256
                Never used ram: 12400
                Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3864) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:01:28 ago, cause: power up
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11548 bytes (slot 0)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 10
                SD card 0 not detected, interface speed: 30.0MBytes/sec
                MCU temperature: min 29.4, current 29.7, max 29.8
                Supply voltage: min 0.9, current 0.9, max 1.0, under voltage events: 0, over voltage events: 0, power good: no
                Driver 0: ok, SG min/max not available
                Driver 1: ok, SG min/max not available
                Driver 2: ok, SG min/max not available
                Driver 3: ok, SG min/max not available
                Driver 4: ok, SG min/max not available
                Cache data hit count 132384348
                Slowest loop: 99.43ms; fastest: 0.06ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Segments left: 0
                Stack records: 0 allocated, 0 in use
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 0.15ms; fastest: 0.00ms
                HTTP sessions: 0 of 8
                • WiFi -
                  Network state is starting
                  WiFi module is disabled
                  ok
                Jesterizeundefined 1 Reply Last reply Reply Quote 0
                  Jesterize @Jesterize
                  That was after running a M552 S0 command
                  • A Former User?
                    A Former User
                    @Jesterize said in Duet 2 WiFi not working:
                    put a new DuetWiFiServer.bin in /sys on the sd card and try running M997 S1 (or say yes to let DWC upgrade, if uploaded through DWC)
                    connect a usb* cable and connect to the serial console if you cannot see the update status in the DWC console.
                    *) please note https://duet3d.dozuki.com/Wiki/USB_ground_loops
                      Jesterize
                      Thanks bearer. Did that, went through the upload process, restarted it, ran M552 S0 and still getting "WiFi module is being started". Running a M122 still says WiFi module is disabled.
                      • A Former User?
                        A Former User
                        just to confirm; it went through 5%, 10% ... 100% and said it was done?
                          Jesterize @A Former User
                          @bearer Yup
                            Jesterize
                            Funny thing is that if I run a M587 command, I get this: M587: Failed to retrieve network list.
                            Why would it have trouble retrieving a list?
                            • A Former User?
                              A Former User
                              either the (wifi) firmware is corrupted, or something has failed.
                              you might be able to get some answers by enabling wifi debug and issuing the firmware update again (will only work with serial console)
                              M111 P14 S1 and M997 S1
                              should look something like
                              Debugging enabled for modules: WiFi(14)
                              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16)
                              Trying to connect at 230400 baud:success
                              Erasing 4096 bytes...
                              Erasing 212992 bytes...
                              Uploading file...
                              5% complete
                              10% complete
                              15% complete
                              20% complete
                              25% complete
                              30% complete
                              35% complete
                              40% complete
                              45% complete
                              50% complete
                              55% complete
                              60% complete
                              65% complete
                              70% complete
                              75% complete
                              80% complete
                              85% complete
                              90% complete
                              95% complete
                              Upload successful
                              WiFi:
                              WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6)
                              WiFi:
                              WiFi: load 0x4010f000, len 1384, room 16
                              WiFi: tail 8
                              WiFi: chksum 0x2d
                              ok
                              WiFi: csum 0x2d
                              WiFi: v3fff168c
                              WiFi: ~ld
                              WiFi module started
                              WiFi: mode : sta(84:f3:eb:42:b0:83)
                              WiFi: add if0
                              WiFi: wifi evt: 8
                              WiFi: scandone
                              WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx
                              WiFi: sleep enable,type: 2
                              WiFi: wifi evt: 2
                              WiFi: scandone
                              WiFi: state: 0 -> 2 (b0)
                              WiFi: state: 2 -> 3 (0)
                              WiFi: state: 3 -> 5 (10)
                              WiFi: add 0
                              WiFi: aid 10
                              WiFi: cnt
                              WiFi:
                              WiFi: connected with xxxxxxxxxxx, channel 13
                              WiFi: dhcp client start...
                              WiFi: wifi evt: 0
                              WiFi: ip:10.10.0.196,mask:255.255.255.0,gw:10.10.0.3
                              WiFi module is connected to access point xxxxxxxxxxx, IP address 10.10.0.196
                              WiFi: wifi evt: 3
                              WiFi: pm open,type:2 0
                              edit:
                              if WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6) is different then most likely wifi or processor has failed
                              if WiFi: csum 0x2d and/or WiFi: v3fff168c is different, then most likely wrong firmware version (i.e. not v1.23) or corrupt binary
                              if it hangs after WiFi: ~ld then i'd wager something is broke, probably the wifi module, but could also be the processor.
                                Jesterize
                                Did that and this is what I got:
                                M111 P14 S1
                                M997 S1
                                Trying to connect at 230400 baud: success
                                Uploading file...
                                5% complete
                                10% complete
                                15% complete
                                20% complete
                                25% complete
                                30% complete
                                35% complete
                                40% complete
                                45% complete
                                50% complete
                                55% complete
                                60% complete
                                65% complete
                                70% complete
                                75% complete
                                80% complete
                                85% complete
                                90% complete
                                95% complete
                                Upload successful
                                ok
                                  Jesterize
                                  Missed the M552 S0. Got this:
                                  M552 S0
                                  WiFi:
                                  WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7)
                                  WiFi:
                                  WiFi: tail 8
                                  WiFi: chksum 0x2d
                                  WiFi: csum 0x2d
                                  WiFi: v3fff168c
                                  WiFi: ~ld
                                  ok
                                  • A Former User?
                                    A Former User
                                    Nothing after ok?
                                    try M552 S-1 followed byM552 S0 it should give you the output from the ESP8266 bootloader at least
                                      Jesterize
                                      It looks like it is hanging on the ~ld. 😞 something is broken
                                      • A Former User?
                                        A Former User
                                        Ah, I might have done M552 S0 before M997 come to think of it.
                                        Anyways, it shows the ESP is trying to boot into mode 3,7 instead of 3,6 - I don't recall the specifics around that issue but smarter people than me should have all the necessary information now at least.
                                        Phaedruxundefined 1 Reply Last reply Reply Quote 1
                                          Phaedrux Moderator @A Former User
                                          @bearer said in Duet 2 WiFi not working:
                                          I don't see anybody like that around at the moment. Will have to wait for DC to have a say.
                                          Only things I can think of to try in the meantime:
                                          1. redownload the wifi server bin file, check that the downloaded size matches, rename it and try flashing again
                                          2. Use these commands to try and clear the saved list of SSIDs and then try starting it again.
                                          M552 S0			; Disable network module
                                          G4 S5			; wait 5 seconds
                                          M588 S"*"			; Clear all saved wifi networks
                                            Jesterize
                                            After doing all that, I get this "Error: M588: Failed to reset the WiFi module to factory settings"
                                            Thanks for trying guys! Hopefully, DC has some good news. Fingers crossed.
