Duet 2 Wifi voltige problem...?
So, I guess I got the programming part sorted but it is not outputting all the voltage for some resin when it is only connected to the power supply.
but the other voltage works when it is connected to the computer
Is the INT 5V EN jumper fitted?
isn't this the same issue? https://forum.duet3d.com/topic/17248/duet-2-wifi-voltage-problem-is-it-the-hardware/4
u3 has a hole in it.
@bearer Yes, I was figuring out how to insert the image and when I wanted to delete it, I was not able to because I replied to my-self which made the post effectively having a reply. Post with a reply is not able to be deleted.
@bearer said in Duet 2 Wifi voltige problem...?:
Sure looks that way.
Is this a new board?
@Phaedrux said in Duet 2 Wifi voltige problem...?:
see the other thread https://forum.duet3d.com/topic/17248/duet-2-wifi-voltage-problem-is-it-the-hardware/4
(and lock this one?)
@bearer Ah thanks. I hadn't made it to that one yet. Locking this one.
