BL Touch Issues RR3
  • HI Team I have been through the forum and for the life of me i can not work this out.
    I just upgraded my firmware to RR3, and am having BL Touch issues.
    Duet2 V1.04 and The Latest firmware V3.1.1
    Upon start up the probe retracts and deploys without an issue.
    When i do a home all it will not deploy, and i have to power off the machine before it hits the bed.
    I have checked the wiring and am using Heater 3 as the signal wire as i did before.
    I will attach the Config.g and the homez & Deploy/ retract as i have seen in other posts.
    Your help would be greatly appreciated.
    ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 27 2020 19:54:19 GMT+1000 (Australian Eastern Standard Time)
    M550 P"Tevo Tarantula" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards
    M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X200 Y200 Z200 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    ; Disable heaters H3-H7 to free up pins ; Added in Line To Disable heaters AK 27/06/2020
    M950 H3 C"nil" ; Added in Line To Disable heaters AK 27/06/2020
    M950 S0 C"duex.pwm3" ; create servo pin 0 for BLTouch
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
    M557 X15:200 Y15:195 S20 ; define mesh grid
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P0 S10 ; deploy BLTouch
    ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P0 S90 ; retract BLTouch
    ; homez.g
    ; called to home the Z axis
    G91 ; relative positioning
    G90 ; absolute positioning
    G1 X15 Y15 F6000 ; go to first probe point
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • My lines for BLT using same wiring:
    M558 P9 C"zprobe.in+zprobe.mod" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
    So I think you need to swap the two lines and use the pin ref as I'm using.
    When testing homeing, raise your Z alot and just trigger the pin with your finger to avoid bed crashing. If it doesn't stop, then do powerdown.
  • Moderator
    Also verify that you actually have 3.1.1 installed by sending M115.
    Once verified send M98 P"config.g" and report any errors.
  • @archie-karagiannis when the bltouch is working you will have to set the G31 X and Y positions, otherwise you measure the bed at the wrong position and the correction will be wrong.
  • @hmortensen
    Thank you so much i replaced my lines with your and it worked a treat ..
    Thanks
  • Moderator
    @hmortensen said in BL Touch Issues RR3:
    +zprobe.mod
    @archie-karagiannis you can remove that part from the M558 line. It's not used by the BLtouch.
  • @JoergS5 Will do so Thank you
  • @Phaedrux ok thank you
