    Prompt where to begin recovery duetwifi and PanelDue
    432
    • juri79undefined
      juri79
      Hello!
      Need help to restore the board.
      Instead of 5V filed 12v
      Not working panel due 7 (when connecting to another panel due 7) - works)
      Not working pin ps on
      the rest of the board is working.
        droftarts administrators @juri79
        @juri79 Please post a good, high resolution picture of your board. I'd have thought that the 5V regulator would be burned. Does it work without USB power connected?
        juri79undefined 1 Reply Last reply Reply Quote 1
        • A Former User?
          A Former User
          which revision of the board?
          probably TR7 you need to look at.
          also see https://github.com/T3P3/Duet/tree/master/Duet2/Duet2v1.04 for schematics
          edit: something doesn't add up, which pin did you connect 12v? Pin 1 on that header is 5v_in and unless you have fitted the ext_5v jumper no harm should come(?); if you had the jumper fitted then it seems odd that everything but PS_ON pin works.
          • juri79undefined
            juri79 @droftarts
            @droftarts
            Yes. works without connecting to the usb
            • A Former User?
              A Former User @juri79
              @juri79 said in Prompt where to begin recovery duetwifi and PanelDue:
              when with a bit of luck it is only the mosfet (TR7) for the PS_ON pin you need to replace. picture would still be helpfull.
              (although TR7 will not have any effect on a faulty PanelDue)
              juri79undefined 2 Replies Last reply Reply Quote 1
              • juri79undefined
                juri79 @A Former User
                @bearer
                ver 1.03
                jumper ext_5v I am not set
                No other voltage was applied to the Board.
                • juri79undefined
                  @bearer said in Prompt where to begin recovery duetwifi and PanelDue:
                  Thank you
                  • A Former User?
                    that explains why the rest of the board is okay, there is no connection from the indicated pin and the rest of the board with out ext_5v jumper.
                    it doesn't explain why PS_ON pin died; maybe you put 12v on the PS_ON pin? (the middle of the three)
                    regardless of where you put 12v on that connector it doesn't offer a clear explanation as to why the paneldue failed, if you can include a picture of the wiring (power off!!) it may help diagnose.
                    • juri79undefined
                      @bearer
                      I have already removed the excess
                      I'll draw it now
                      • juri79undefined
                        • A Former User?
                          A Former User
                          I cannot see how connecting 12v to that pin with the ext_5v jumper removed should cause any problem at all, its effectively disconnected.
                          could there be some loose strands or something on the connections causing a short?
                          • juri79undefined
                            @bearer
                            Maybe due to the fact that I pressed the power button?
                            • A Former User?
                              A Former User
                              a short between PS_ON and ground would explain why that mosfet may have failed. but it has no connection to a failed paneldue so there is something missing from the equation.
                              • juri79undefined
                                @bearer
                                This of course will not help, but when turned on, the entire Board (LEDs) and screen flashed
                                • A Former User?
                                  A Former User
                                  Unless well lit and focused pictures of the boards have any clues I don't think I have more to add I'm affraid.
                                  Replacing TR7 (tiny mosfed between the Vin terminal and the always on fan) will likely fix the PS_ON problem, but no idea why or what caused the paneldue issue.
                                  • juri79undefined
                                    @bearer
                                    Thank you again.
                                    if restore - write
