Print artifacts
What i bet is happening.
The prints are unuseable.
Tweaking the extrude startpoints gives abit better results.
Still not even close.
Missing 5mm of extrude on wall 2 on the outside, does a weird loop.
Hot end and extruder are calibrated these problems are on nozzles 0.6mm and larger, test prints are printed on ApolloX 255°C nozzle, 95°C bed,50°C enclosure, print speed set to 12-24mm/s mooves are on 24mm/s, 1.2mm nozzle.
Layer adhesion is good and the parts are stong.
What can i do to extrminate the holes and the seam.
Things i have tried.
-Wipe settings, 5.2mm does something.
-Coast settings, if coasting is on the results are worse.
-Print speed, does nothing ofc over 40mm/s gets layer adhesion problems.
-Retract settings, does absolutely nothing.
-Temps are spot on.Using Cura slicer 4.6.1, i dont mind changing if there is something better out there, since this is most likely a slicer problem.
Is it a Bowden setup? If so, have you applied pressure advance ?
Its a direct drive.
Post your config.g so we can see your speed settings.
What retraction settings are you using?
Are you using pressure advance?
Is the tube supposed to have a gap between walls?
Can you share a saved .3mf file form cura so we can see your model and print settings?
These problems are only on cylinders, printed a pyramid as a test and no vetical lines, yes the cylinder has no infill.
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15600.00 Y15600.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
M201 X2800.00 Y2800.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1900 Y1900 Z1900 E1197 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeoutAllso what is this pressure andvance setting?
https://duet3d.dozuki.com/Wiki/Pressure_advance
I suggest you try using firmware retraction so that you can adjust your settings while the print is running so you can see the results.
I happened to be printing a similar type of object recently. An adapter to go from one size cylinder to another. The model was a solid wall, no gap between like you have. I also found there was a bit of a gap at the start of the next layer. Cura was set to use 4 walls, inner wall first, and then outer wall. Retract on layer change was set. To get rid of the gap I had to use slower unretract than I was using for retraction and then add a slightly amount of extra prime amount.
There macros may help you in your real time tuning.
https://forum.duet3d.com/topic/6181/tuning-macros-menus-accel-jerk-retraction-pressure-advance
Thanks, allso found out that stratasys has a patent for ''intelligent'' tool paths, it just basicly overlaps the ends so there is no gap, how can one justify to patent a sring of gcode is beyond me.
