    Feed Filament until hitting okay/ display button
    319
    • taconiteundefined
      taconite
      Hey guys,
      this is an example of a filament load macro:
      M291 P"Please wait while the nozzle is being heated up" R"Loading PETG Grey" S3 T20 ; Display message
      G10 S220 R200                ; Set current tool temperature to 235C, standby temp to 200C
      M291 P"Please put the Filament in the Extruder" R"Loading PETG Grey" S3     ; Display message and wait for resoponse
      M302 P1
      G1 E50 F500 ;(1)
      M302 P0
      M291  P"Please wait while the nozzle is being heated up" R"Loading PETG Grey" T20
      M116                    ; Wait for the temperatures to be reached
      M291 P"Feeding filament..." R"Loading PETG Grey" S3 T5               ; Display new message
      G1 E10 F600         ; Feed 10mm of filament at 600mm/min
      G1 E750 F2000         ; Feed 470mm of filament at 3000mm/min
      G1 E90 F300      ; (2) Feed 20mm of filament at 300mm/min
      G4 P1000 ; Wait one second
      G1 E-2 F1800 ; Retract 10mm of filament at 1800mm/min
      M400 ; Wait for moves to complete
      M291  P"Loading done" R"Loading PETG Grey" T20
      M292 ; Hide the message
      G10 P0 R180 S220  ; Set active and stand-by temperature
      How is it possible to change it the way that in (1) and (2) filament is feed until I hit an "okay"-Button in a pop-up message (no physical button)
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • A Former User?
        A Former User
        Not sure if you can do that, not even sure if you can bring up a message with the jog buttons for the extruder but try
        M291 R"Jog extruder" E1
        • deckingmanundefined
          deckingman @taconite
          @taconite I'm 99% sure that you can't interrupt a move other than maybe doing an emergency stop. Something like this has come up on a few previous occasions and I think the only thing you can do is replace one long move with a number of smaller, segmented ones.
          • A Former User?
            A Former User
            I'm 100% sure I agree 😁 ☝
            Also the normal dialouges won't offer an estop, i also believe it blocks the normal stop button on the paneldue and dwc so I didn't tink more of it.
            The only alternative thought i had was to use daemon.g to check a condition and keep extruding until the condition is cleared - but I haven't tested what sort of intervals that would run at and how (un)responsive or jittery it would be (edit: and it would require RRF3)
            • taconiteundefined
              taconite
              Thank you for your replies @deckingman @bearer . Makes kind of sense and I thought about using Conditional G-Code in RRF3 like (attention pseudo-code):
              while (!"message button pushed")
              G1 E10 F500
              But I have absolutely no idea if there is a "feature" like that
              EDIT: btw that is what you guys proposed - the only question is if the "button" can be emulated as variable for the while loop
              Custom ANET A8
              • A Former User?
                A Former User @taconite
                @taconite said in Feed Filament until hitting okay/ display button:
                as you required to not use a physical button I think the only option is to have the loop in the daemon.g file and present the button in your macro/config/part g-code.
                And I do believe as of RRF3.2 it should support sharing the loop condition as a variable.
                edit: more pseudo code
                in daemon.g (maybe if instead of while if there are other tasks that also need to run?)
                while start-condition
                   G1 E10 F500
                and in your macro
                start-condition = true
                M291 R"Press OK to stop extruding" S2
                start-condition = false
                edit: but as I said, I'm not sure this will work well due to how often (or not often) daemon.g runs
                • taconiteundefined
                  taconite
                  @bearer nice approach and i guess it will work when variables are introduced
                  Custom ANET A8
                  • A Former User?
                    (you could try experimenting with it now by looking here for inspiration https://forum.duet3d.com/topic/14376/global-variables-between-macros)
                    • taconiteundefined
                      taconite
                      @bearer thank you for pointing me in the right direction - i got it to work 🙂
                      btw I am really looking forward to the use of variables - than we can use more potential of the board
                      Custom ANET A8
