filament sensor def. not very usable with PA
7/4/2020, 7:59:06 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, no data received 7/4/2020, 7:59:21 PM M32 "0:/gcodes/elephant2.gcode" File 0:/gcodes/elephant2.gcode selected for printing 7/4/2020, 8:11:09 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.121mm/pulse, measured minimum 0%, maximum 115% over 672.5mm 7/4/2020, 8:39:27 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.120mm/pulse, measured minimum 0%, maximum 117% over 2924.6mm 7/4/2020, 8:50:36 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.120mm/pulse, measured minimum 0%, maximum 120% over 3931.8mm 7/4/2020, 9:06:13 PM M591 D0 P7 C"^e0stop" L0.119 R90:110 E3 S0 ; same data again to reset stat 7/4/2020, 9:06:17 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, no calibration data 7/4/2020, 9:06:27 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.120mm/pulse, measured minimum 87%, maximum 107% over 24.4mm 7/4/2020, 9:22:46 PM M591 D0 Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.122mm/pulse, measured minimum 76%, maximum 119% over 1688.1mm
looks like pulsing with PA does not work
... I did not notice any reverse action other than retractions but this is just unreliable to use
as the print progresses the "sensitivity" value increses (real value here is ~0.118656), the min and max both decrease/increase so much that the measurements makes no sense
EDIT: references for earlier talks on this:
RRF 3.1.1 M572 breaks M591When you enable pressure advance, depending on the speed and acceleration you use, the extruder may reverse during the last part of a printing move. So it's important that the filament monitor senses the direction of motion and passes it to the Duet along with the amount of motion, as the Duet3D filament monitors do. If the filament monitor just sends motion pulses with no direction information, then the reverse motion will be misinterpreted as forward motion; so it will appear to RRF that there is too much filament motion.
Here's my printable optical encoder wheel filament sensor!
no point in building one if using PA with current firmware; if and how to "fix" it might be better discussed in a dedicated thread leaving the warning here for now?
Well according to that dump the device is disabled. Is that true?
@fcwilt said in filament sensor def. not very usable with PA:
yes, hence it did not pause the print when the read data went over 110% or below 90%, otherwise it behaves just like it's enabled
@fcwilt this is not new, we already discussed it in different thread as the mechanism does not take filament direction into account. During retractions it just ignores input. PA speed/slow down the extruder (and reverse it in some cases) and while I never notice any reverse movement on my setup looks like the slowdown is also not followed up with the filament tracking module
@dc42 sorry I know you are now overloaded with new hw but if you can help out a bit maybe we can solve this
I'm looking at the MagneticFilamentMonitor and it's sending a data word with 10bit "filament position". If I convert output of the encoder to a compatible output and send "filament position" that I track locally so increase in one direction, decrease in other (overflow?!) will this work with PA and DAA ? Is the only problem direction or there are other issues with PA/DAA not handling pulse inputs?
I see that LaserFilamentMonitor is sending 11bit position with 100count/mm configured. Same question as magnetic one?
It would be super simple to create a small board that takes AB from encoder and generates these signals for the RRF. I can go with ATtiny44A to be compatible with existing boards, should be quick and simple project, but makes no sense in doing it if it will not work. @omni has duet's laser sensor and he's getting similar span of min/max as I am with it with PA+DAA on so that's why I'm bugging you with questions
looks like DDA is not a problem, filament monitor code fetches
DDARing::GetAccumulatedExtrusion
so it's just PA that's not in this chain
@arhi said in filament sensor def. not very usable with PA:
so it's just PA that's not in this chainGetAccumulatedExtrusion looks at the actual number of microsteps taken, so it does take PA into account.
@dc42 said in filament sensor def. not very usable with PA:
direction too? it reduce the number if PA reverses the direction of the extruder?
Yes. However, there is a short delay between the filament monitor starting to take a reading and then sending it to the Duet, so PA does reduce the accuracy of the correlation a little.
I found a bug in my design that allowed filament to slip, that's why I had those "zero" readings... now with fixed design it's much better:
Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.124mm/pulse, measured minimum 79%, maximum 131% over 9440.3mm
this looks usable. If a get a clog/block the min will quickly drop below 50% and the print will pause.. so I just need to add a bigger span than original 90-110 and it should work.
Looking at the two "smart" sensors too, I think I'll make one attiny adapter for the encoder type to behave like laser or magnetic one or you think it is better to add a new type of sensor (smart encoder for e.g.) ?
def. works.. finished few prints with enabled sensor with PA working ..
Pulse-type filament monitor on pin e0stop, enabled, sensitivity 0.124mm/pulse, allowed movement 50% to 200%, check every 3.0mm, measured sensitivity 0.124mm/pulse, measured minimum 74%, maximum 117% over 3091.4mm
so if PA is not reversing everything is ok. the 0% minimum was a hardware failure (fixed :D)
so def makes sense to add a converter to convert quadrature output to the position data to send like those smart sensors
