Robotic kinematics
@JoergS5 I'm reading the discussion so I can know what kind of progress have already been made.
I've noticed that the robot viewer is not avaiable anymore, is there any specific reason for that?
@YuriConfessor said in Robotic kinematics:
The robot viewer was based on Denavit-Hartenberg, and I changed to screw theory. And second reason is, DWC is based on TypeScript now instead of JavaScript and I have not migrated yet. A third point is that I'd like to base all on C++ code. I'm still searching for a good solution to visualize. Qt (using C++) offers a web interface, which could be used in DWC, but unfortunately not in SBC mode (a Raspi connected to Duet).
@JoergS5 Hi, has there been any updates on this? I am seeing that in the documentation the parameters are still D and H. Is it still in the released version of RRF or has it already been changed?
@Toaster0042 D is a documentation mistake, I'll check and remove the wrong parts. It's all based on screw parameters. In respect to axis definitions the C parameter.
@JoergS5 I have tried using the 4 axis pelletized earlier and was unable, will you be releasing it soon? I am using this for a school project and tought it was working so I am in a bit of trouble now
@Toaster0042 I will make a release soon.
@Toaster0042 You can help me by providing
- some pictures of the robot arm. Special interest is how the parallelogram is built, i. e. is it a triangle or some other solution. How is the parallelogram connected to the endpoint?
- exact measures of arm lengths
- to which parts are the steppers connected
This allows me to build the same and verify the code before publishing.
@JoergS5 I can get the measurements to you a bit later but this is the arm I am using https://www.instructables.com/Build-a-Giant-3D-Printed-Robot-Arm/
@Toaster0042 I don't need the measurements, because it's not a 4 axis parallel robot.
It's like an industrial 6 axis robot, but without the 6th axis. Instead the 6th axis, the 6th actuator is used to grip.
I have code for the 6 axis robot, but not for your 5 axis plus gripper. I have to think about it. Your project is interesting, I want to support your robot type if possible. I will ask you to test code with your robot to verify the code.
@JoergS5 ah ok, I tought it would fall under the 4 axis robot with an aditional rotating joint, I am fine with testing it I simply need to finish printing it as I have not finished it yet and was trying to get the firmware set before but I will be happy to test the code
I have time in May and June now to proceed developing robot kinematics. The order is
- 4 axis parallel (the black robot arm), probably as a quick-and-dirty approach first for @YuriConfessor
- DWC plugin to design and analyse a given model
- CoreXY/Prusa/Cartesian 5 axis AC and BC
- 6 axis robot
- testing whether Qt is a possibility for a designer/slicer
- elaborate tool design. My personal priority is using robot for CNC, so I'll work on support for different tools (tool shape etc).
I'll use 3.5.1 as basis.
