    Robotic kinematics
    MultiAxis Printing
    22
    389
    49.1k
    • JoergS5undefined
      JoergS5 @tony73
      @tony73 said in Robotic kinematics:
      I have a lathe with modifications for manual cnc I could do the important pieces in aluminum.
      This will be sufficient. It would be an advantage to already have a 3D printer, but I have a plan to start without. I will release all what I am doing to build the robot.
      tony73undefined 1 Reply Last reply Reply Quote 0
      • tony73undefined
        tony73 @JoergS5
        @JoergS5
        I have a 3d printer I took it for granted !!some pieces for my scara are created with 3d printing !
        JoergS5undefined 1 Reply Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @tony73
          @tony73 I only ask because I have an idea to use 3D printed gears, and one needs a printer already to create it. But I'll explain in a few days.
          tony73undefined 2 Replies Last reply Reply Quote 0
          • tony73undefined
            tony73 @JoergS5
            @JoergS5
            ok! I look forward to hearing from you !
            • tony73undefined
              tony73 @JoergS5
              @JoergS5
              good morning ! how is work on the robot going on?
              • JoergS5undefined
                JoergS5 @tony73
                @tony73 hello, my first try was too flexible, I am currently building version 2. You'll see it in a few days.
                • tony73undefined
                  tony73 @JoergS5
                  @JoergS5
                  OK, see you soon!
                  • JoergS5undefined
                    JoergS5 @tony73
                    This post is deleted!
                    • JoergS5undefined
                      JoergS5
                      @dc42 I have two short questions and hope you can easily answer them:
                      The M208 XYZ, are they cartesian coordinates, and when using U it is meant as a second X? For rotational actuators, I would use the result of the kinematics world coordinates for the M208 values, not the angles? Do I understand this correctly?
                      I have to inform the kinematics in advance before the G0/G1 move starts, what the complete movement will be. I added a seperate method for this in the kinematics. Where shall I add the call? (DDA/Move/...Init/Spin?) and are there additional parts where I have to add it (mesh compensation eg).
                        It's entirely up to you what you use the U axis for. In the CNC world, conventionally UVW behave like a second XYZ system, and ABC are rotational axes. But RRF doesn't require that.
                        • JoergS5undefined
                          JoergS5 @dc42
                          @dc42 I meant are M208 values cartesian coordinates or stepper positions?
                            dc42 administrators @JoergS5
                            @JoergS5 said in Robotic kinematics:
                            They are in whatever units your kinematics assumes for U parameters in G1 commands.
                            • JoergS5undefined
                              JoergS5 @dc42
                              @dc42 ok thanks, I try to use it correctly.
                              • tony73undefined
                                tony73 @JoergS5
                                @JoergS5
                                good morning ! I took the two files with the latest changes FiveAxisRobotKinematics.h and FiveAxisRobotKinematics.cpp I put them in rrf 3.1.0 as I always did, I tried to in eclipse to recompile the .bin gives me this error,
                                could you help me ? I don't know where I'm wrong!
                                • JoergS5undefined
                                  JoergS5 @tony73
                                  @tony73 you're right, I missed checking it in into github. I'll do this in a minute. The variables are a prepration to support P3 (hotend in the direction of the movement) and a new P4.
                                  Sorry that I overlooked it.
                                  • tony73undefined
                                    tony73
                                    @JoergS5
                                    OK! eclipse firmware reloaded works! I would like to start building a robot that looks like this
                                    with example link 1 /150mm, link 2/ 200mm, link 3/ 200mm, link 4/ 100mm, link 5/ 80mm
                                    the (link 4 could be 100mm? considering that I don't know if link 2 can go to less than 0 degrees (type arm 2 max 75 degrees min -45 degrees? and could you say reduction ratio would serve on the basis of these arms, for the 5 engines?
                                    maybe I made a wrong speech!
                                    if link 1 is 150mm, I can make link 4 of 100mm that is 50mm less than link 1, can there be a problem or can it be done? can create problems at link 2 for min angle 0?
                                    • JoergS5undefined
                                      JoergS5 @tony73
                                      @tony73 I think you confuse some of the distances, What you mark as link 1 distance has no meaning. Only how much it can rotate is important.
                                      => to answer your question, different axis lengths are no problem. Longer will probebly be more stable. I will use between 100 and 200 also.
                                      Link 2 min angle 0 is no problem. You must calibrate the angle at a different angle (eg 90 degree).
                                      Your question according reduction ratio: which ratio do you plan?
                                      At the 5 you must assemble something horizontal to hold a hotend if you want to use it for 3d printing.
                                      The robot as such looks very stiff and will be precise (if the ratio is ok) imho. In axis 5 could be a harmonic drive. A planetoid gear could have backlash, but you could run it in P0 mode.
                                      Axis 1 is very important to be precise (exactly horizontal rotation eg), you should consider making the rotating plate as big/good/stiff as possible.
                                      • tony73undefined
                                        tony73 @JoergS5
                                        • tony73undefined
                                          tony73 @JoergS5
                                          @JoergS5
                                          ok! I take note of all the advice! and thank you for your help! if these were the lengths of the robot arms ((X0.0: 0.0 Y0.0: 0.0 Z100.0 L200.0: 200.0: 100.0: 80.0)) what reduction ratio would you use so that the 5 motors have excellent precision?
                                          about the second robot you are building how long do you need to finish it?
                                          • JoergS5undefined
                                            JoergS5 @tony73
                                            @tony73 I don't exactly know the best ratio, the commercial robots often have 1:30 for every axis. My approach will be to calculate mathematically which is the best ratio:
                                            high ratio means higher precision and more torque, but slower. So there will be an optimal ratio for the desired speed. Regarding the maximal extruder speed, the robot has a maximum speed. More speed (= low ratio) is not necessary and would result in lower precision. High ratio would be slow. The arm lengths are also important.
                                            To calculate is on my long todo list...
