    Robotic kinematics
    MultiAxis Printing
    22
    389
    46.9k
    • JoergS5undefined
      JoergS5 @tony73
      @tony73 before developing, I thought about whether to build this type of robot with the rotating 4th axis (6 in total), but I saw no advantage for a 3D printer, because the hotend holder shall be horizontal, the arm 4 vertical. And arm 5 long enough, so the extruder and other hotend parts can rotate freely around arm 4.
      In the future the robot could be used for other tasks, CNC for example, where this flexibility would make sense. If I can master the kinematics/inverse kinematics task, I would like to develop this also. It is more complex of course.
      Your robot offer has a relatively low gear ratio (my guess is 1:10 or even less). I suspect the precision is not good enough for 3D printing. But I have no experience, so it's only a guess.
      I plan to develop and describe DIY building a robot as easy as possible in the reprap spirit (eg 3D print some of the printer parts*)) and describe it. It is an option for you to wait and decide whether it's better to build instead of buy. I understand your restrictions, but you have no project time deadline.
      *) not the stiff parts of course!
      tony73undefined 1 Reply Last reply Reply Quote 0
      • tony73undefined
        tony73 @JoergS5
        @JoergS5
        these are the motor reduction values ​​that they describe, for you to see.
        I was evaluating what I could do, I'm willing to wait even to see your robot and I don't know how many hours of work it takes but if they are reasonable I could follow you if you will release documentation to reproduce it, I have a lathe with modifications for manual cnc I could do the important pieces in aluminum.
        I know that a 6 axis for 3d printing can be wasted, but as you said in the cnc field it is perfect, but let's go step by step! how much do you miss at the end of the robot?
        JoergS5undefined 1 Reply Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @tony73
          @tony73 said in Robotic kinematics:
          This will be sufficient. It would be an advantage to already have a 3D printer, but I have a plan to start without. I will release all what I am doing to build the robot.
          • tony73undefined
            tony73 @JoergS5
            @JoergS5
            I have a 3d printer I took it for granted !!some pieces for my scara are created with 3d printing !
            • JoergS5undefined
              JoergS5 @tony73
              @tony73 I only ask because I have an idea to use 3D printed gears, and one needs a printer already to create it. But I'll explain in a few days.
              tony73undefined 2 Replies Last reply Reply Quote 0
              • tony73undefined
                tony73 @JoergS5
                @JoergS5
                ok! I look forward to hearing from you !
                • tony73undefined
                  tony73 @JoergS5
                  @JoergS5
                  good morning ! how is work on the robot going on?
                  • JoergS5undefined
                    JoergS5 @tony73
                    @tony73 hello, my first try was too flexible, I am currently building version 2. You'll see it in a few days.
                    • tony73undefined
                      tony73 @JoergS5
                      @JoergS5
                      OK, see you soon!
                      • JoergS5undefined
                        JoergS5 @tony73
                        This post is deleted!
                        • JoergS5undefined
                          JoergS5
                          @dc42 I have two short questions and hope you can easily answer them:
                          The M208 XYZ, are they cartesian coordinates, and when using U it is meant as a second X? For rotational actuators, I would use the result of the kinematics world coordinates for the M208 values, not the angles? Do I understand this correctly?
                          I have to inform the kinematics in advance before the G0/G1 move starts, what the complete movement will be. I added a seperate method for this in the kinematics. Where shall I add the call? (DDA/Move/...Init/Spin?) and are there additional parts where I have to add it (mesh compensation eg).
                            It's entirely up to you what you use the U axis for. In the CNC world, conventionally UVW behave like a second XYZ system, and ABC are rotational axes. But RRF doesn't require that.
                            • JoergS5undefined
                              JoergS5 @dc42
                              @dc42 I meant are M208 values cartesian coordinates or stepper positions?
                                dc42 administrators @JoergS5
                                @JoergS5 said in Robotic kinematics:
                                They are in whatever units your kinematics assumes for U parameters in G1 commands.
                                • JoergS5undefined
                                  JoergS5 @dc42
                                  @dc42 ok thanks, I try to use it correctly.
                                  • tony73undefined
                                    tony73 @JoergS5
                                    @JoergS5
                                    good morning ! I took the two files with the latest changes FiveAxisRobotKinematics.h and FiveAxisRobotKinematics.cpp I put them in rrf 3.1.0 as I always did, I tried to in eclipse to recompile the .bin gives me this error,
                                    could you help me ? I don't know where I'm wrong!
                                    • JoergS5undefined
                                      JoergS5 @tony73
                                      @tony73 you're right, I missed checking it in into github. I'll do this in a minute. The variables are a prepration to support P3 (hotend in the direction of the movement) and a new P4.
                                      Sorry that I overlooked it.
                                      • tony73undefined
                                        tony73
                                        @JoergS5
                                        OK! eclipse firmware reloaded works! I would like to start building a robot that looks like this
                                        with example link 1 /150mm, link 2/ 200mm, link 3/ 200mm, link 4/ 100mm, link 5/ 80mm
                                        the (link 4 could be 100mm? considering that I don't know if link 2 can go to less than 0 degrees (type arm 2 max 75 degrees min -45 degrees? and could you say reduction ratio would serve on the basis of these arms, for the 5 engines?
                                        maybe I made a wrong speech!
                                        if link 1 is 150mm, I can make link 4 of 100mm that is 50mm less than link 1, can there be a problem or can it be done? can create problems at link 2 for min angle 0?
                                        • JoergS5undefined
                                          JoergS5 @tony73
                                          @tony73 I think you confuse some of the distances, What you mark as link 1 distance has no meaning. Only how much it can rotate is important.
                                          => to answer your question, different axis lengths are no problem. Longer will probebly be more stable. I will use between 100 and 200 also.
                                          Link 2 min angle 0 is no problem. You must calibrate the angle at a different angle (eg 90 degree).
                                          Your question according reduction ratio: which ratio do you plan?
                                          At the 5 you must assemble something horizontal to hold a hotend if you want to use it for 3d printing.
                                          The robot as such looks very stiff and will be precise (if the ratio is ok) imho. In axis 5 could be a harmonic drive. A planetoid gear could have backlash, but you could run it in P0 mode.
                                          Axis 1 is very important to be precise (exactly horizontal rotation eg), you should consider making the rotating plate as big/good/stiff as possible.
                                          • tony73undefined
                                            tony73 @JoergS5
