    Duet 2 Wifi with BLTouch
    • eculverundefined
      eculver
      I have a large format printer that I am attempting to use a Duet 2 Wifi with. I have gone through the tutorials for setup, and have everything working except for my BLTouch sensor. I followed the tutorial for this and have it wired correctly.
      I.E. positive to 5v, negative to ground, and signal to heater 3 on the 3 wire cable, and white to Z probe in and black to ground on the Z probe plug
      It responds to the commands M280 P0 S10 and M280 P0 S90 for lowering and raising the sensor, but the webview does not display a change in Z probe status.
      When I run g30 the bed immediately begins to raise towards the head without the probe ever deploying which leads to me having to use E-stop to prevent it from crashing. What do I need to do to fix this?
      System:
      Firmware Version: 3.0 (2020-01-03b3)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      config.g:
      M550 P"Modix Big 60" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
      M92 X200.00 Y100.00 Z2011.76 E509.30 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z3600.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z2400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X600 Y600 Z600 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M307 H3 A-1 C-1 D-1
      M558 P9 C"^zprobe.in" H5 F500 T4000 R1 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
      M950 S0 C"exp.heater3"
      G31 P25 X-25.3 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M557 X15:215 Y15:195 S20 ; define mesh grid
      homeall.g:
      G91 ; relative positioning
      G1 H1 X-605 Y-605 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-605 Y-605 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      homez.g:
      G1 X15 Y15 F6000 ; go to first probe point
      Deployprobe.g:
      M280 P3 S10 I1
      Retractprobe.g:
      M280 P3 S90 I1
      I feel like I've been beating my head against a wall for the past week trying to solve this so any help would be greatly appreciated.
      • Scachiundefined
        Scachi
        When the state always reads 1000 make sure to check if the white wires are crimped correctly/a signal can pass through it.
        Test it with a multimeter.
          Phaedrux Moderator @eculver
          @eculver said in Duet 2 Wifi with BLTouch:
          But does it respond to M401 and M402? I'm guessing not if your deploy and retract macros are as you've shown them.
          Deployprobe.g:
          M280 P3 S10 I1
          Retractprobe.g:
          M280 P3 S90 I1
          Are you using M280 P3 or M280 P0? It should be P0 because that's the servo index number used in your M950 command to create the servo control pin.
          M307 H3 A-1 C-1 D-1
          Remove that command. Not used in RRF3.
          Update your firmware and DWC to 3.1.1
          The web view may not display 0 or 1000 accurately for the BLTouch because it only flashes briefly as triggered and immediately resets the pin, so it's not a good indication of function. Once you have the deploy and retract sorted use this to test the probe.
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          eculverundefined 1 Reply Last reply Reply Quote 0
          • eculverundefined
            eculver @Phaedrux
            @Phaedrux
            Thank You, Fixing the Deploy and retract probe files solved my problem. I was unclear as to what was being defined on those files and thought they had been set correctly.
