Losing connection with board
I keep losing connection with the board. I just get the standard AJAX message and no explanation. Its pretty random, Just now I connected, everything looked good, then about 30 sec in it said it disconnected. Before it was doing it in the middle of a print. The print kept going and finished, but I could only stay connected for a couple of min at a time. When that one finished i rebooted the board and my PC to see if that helped. Its hit or miss now. How do I track this down ? So I can give more useful information.
What firmware versions are you running?
M115
FIRMWARE_NAME: RepRapFirmware for Duet Ethernet FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet Ethernet 1.0 FIRMWARE_DATE: 2017-04-09
I have the same problem as far as I can tell. I have the ethernet with the newest beta. Let me know how I can contribute.
…and its worse today
I will reformat my card and put the files back and see if that will help.
Usually there is a little more detail provided in Ajax error messages. Which Duet Web Control version are you running?
I am getting " Communication Error
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again."
Web Interface Version: 1.16
M115
The firmware version you're reporting isn't the Duet Web Control version. You can check the DWC version from the settings tab in DWC.
Perhaps there is an IP address conflict between the Duet and something else on your network?
Firmware Name: RepRapFirmware for Duet Ethernet
Firmware Electronics: Duet Ethernet 1.0
Firmware Version: 1.18.1 (2017-04-09)
Web Interface Version: 1.15a
Web Interface by Christian Hammacher
Licensed under the terms of the GPL v3
Dark theme kindly provided by FotomasNothing else is close to the number that the router assigned it.
I had a similar problem when the signal strength at the printer was low. I setup my nearest AP with a unique SSID and changed the printer setting to use that SSID to be sure the printer was connecting to the that specific AP. Then the signal strength was much better and the problems went away.
I just connected and it forgot that I set it to the dark version of the screen layout. grr
is the version I just listed not stable, if not which one should I look for?Error reason: timeout
M552? I have that set to what my router gave it as an ID
No wifi here. I will be changing out the switch next week. I’ll pay attention and see if the disconnects go away. Everything is dhcp and I haven’t had duplicate up issues before.
the router has the Duet listed as a Static address vs DHCP, just looked, its is also the only device that has 3 digits for the last sequence of numbers.
Can you confirm that you only have one Duet on the network? I had problems connecting to a Duet Ethernet yesterday, until I realised that I had a Duet 0.6 on the same network and they were both using the default MAC address.
I only have one board, and only one is listed on the router info screen. it has My computer, my laptop when its on, my phone and the Duet board. short list so its easy to spot.
Another oddity showed up this morning, the small print I was doing, a replacement part was nearly finished. I could see the part was on the last few layers. yet the DWC told me I was only 56.6% done. It has been spot on before. Down right scary in how close it has been till this. I will be keeping an eye on it.
That usually means that you have a G1 Z command in your end gcode to raise the print head when the print is complete, and that command is confusing the object height detection. The remedy is to add a comment starting with ;E to that line.
Are you connecting using a DNS name, or directly via IP address? I was having similar issues when connecting via a DNS host name, and someone else here suggested I try via IP address, as the mDNS responder might be having issues. I've switched to connecting via IP address only, and have not had an unexplained disconnection since that time.
John
I have a G1 E-15 F9000 as the first line in my closing script, I'll add the suggested comment in
John
Using the IP address here
That shouldn't cause any problems, it's when you have a G1 Z line in your closing script that the object height is likely to be read incorrectly, because the firmware looks for the last G1 Z line in the file and assumes that indicates the start of the last layer.
So then might it not be a good idea to but code in the starting script to tell it where it is? Maybe a G30, or do G30 and input that value somehow? Is there something else in my code throwing it off. I used the ones I had for an i3 as a basis. This is my first Delta machine so things might not translate the way I think they do.
open script
G28 ; home all axes
M280 P3 S10 I1 ; DROP PIN
M98 Pbed.gclose script
G1 E-13.0 F9000 ;E
G90
G0 Z400 F1800
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M106 S0
M84 ; disable motors
