    RRF Config Mapping
    1.8k
    • printthatthingundefined
      printthatthing @Phaedrux
      @Phaedrux i was missing M501 in config.g
      Restarted boad but getting same error when trying to heat bed.
      Tried to run M307 H0 S90 again but it fails with Error: M307: bad model parameters
      ; config-override.g file generated in response to M500 at 2020-07-10 23:02
      ; Heater model parameters
      M307 H0 A340.0 C140.0 D5.5 S1.00 V0.0 B1
      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
        In config.g change M307 H0 B1 S1.00 to B0
        Then delete your config-override.g and run M307 H0 S90 again after a reboot. Then save with M500.
        printthatthingundefined 1 Reply Last reply Reply Quote 0
          Also make sure you're starting from a cold bed state.
            @Phaedrux said in RRF Config Mapping:
            Executed M307 H0 S90 after the suggested changes.
            Update:
            My bad, it might be M303 H0 S90
              Phaedrux Moderator @printthatthing
              @printthatthing said in RRF Config Mapping:
              Update:
              😑 Yes of course.
                Update:
                😑 Yes of course.
                Now it works fine:) Thank you so much for all support.
