Solved My Duet2WiFi stopped responding
I have a problem with my Duet2WiFi board. The board is brand new, I've got it a couple of days ago to replace the original, proprietary control board in my printer.
For testing I used a Thinkpad power supply outputting 19V (heaters are disconnected, the power supply can supply enough current to power the rest of the system). I have upgraded the firmware to 3.1.1. The printer uses optical endstop sensors, and I could not make them work. The status LEDs on the board were indicating correct state of the switches, but software was registering state changes only on Z axis.To verify whether the problem was with the sensors or the inputs, I disconnected the switch connectors (with power disconnected), and connected a jumper wire to one of the inputs to check how it responds to supplying 0 and 3.3V from the pins on the sensor connector. Unfortunately at this point the board stopped responding. I'm not sure whether it did not come on after connecting the power, or when I was connecting the jumper cable to the 0/3.3V pins. I was watching the input status indicators on the web interface, and noticed the "Connecting" popup still on when I started to investigate why I don't see any changes.
The serial USB interface still works, disappears when I press the RESET button, so I assume the CPU works. The DIAG LED stays on all the time, the serial console does not respond to input, and the board does not respond to IP pings.
I would appreciate an advice how to debug and fix the issue.
@piranha32 said in My Duet2WiFi stopped responding:
try this https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
Thanks, it fixed the issue. Verify on the firmware before erasing showed >90 pages with errors. Do you have an ideas on what might have caused the failure?
@piranha32 endstop pin order is different on duet boards compared to typical RAMPS derivatives, see https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Connecting_different_types_of_endstop_switch
Possibly static discharge to the +3.3V or +5V rail. Are your stepper motor cases and hot end metalwork grounded?
@oliof said in My Duet2WiFi stopped responding:
I wired the connectors according to the description of the pinout. The status LEDs were showing correct state, status is read correctly on all 3 inputs when I use a jumper wire, so the most likely reason why the controller doesn't read the endstops properly is incorrect voltage level from the sensor in "low" state. I'm going to add a buffer circuit between the sensor and the board, and I hope this will solve the problem.
@dc42 said in My Duet2WiFi stopped responding:
Possibly static discharge to the +3.3V or +5V rail. Are your stepper motor cases and hot end metalwork grounded?At the moment there is no grounding connection. ESD was my first suspicion, but I find it very weird that a minor discharge would wreck so much havoc on the firmware in flash (over 90 pages did not pass verification before erase).
@piranha32 could be that you inadvertently shorted the erase pins, then on next reset (possibly when endstop shorted) the firmware got erased.
@droftarts said in My Duet2WiFi stopped responding:
It is possible, but highly unlikely. All the wires I used were insulated, the board was sitting on a non-conductive surface, and I don't use the endstop connectors right next to the erase pins.
I'm worried that it may happen again when the board will be installed in the printer, so I'd like to understand what's happened, and protect against it. -
first reported case (afaik), and turn off the power when working on it as well as don't work on it without a proper ground strap to ground youself about summs it up i rekon.
