    rrf3 bltouch what have a missed.
    • peter247undefined
      peter247
      Hi , trying to set on my bltouch on my duetwifi running 3.1.1.
      Followed the docs . but must have missed something.
      I'm on heater 3 and using pins 1 , 2 , 8 ( heater 3 ) using this in my config .
      M558 P9 C"^zprobe.in" H5 F100 T2000				; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"exp.heater3"							; create servo pin 0 for BLTouch
      G31 P500 X0 Y0 Z2.5                           	; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20
      but can't get it to deploy with M280 P0 S10 .
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        Phaedrux Moderator @peter247
        @peter247 said in rrf3 bltouch what have a missed.:
        Double check the wiring. You config looks ok, provided you're actually connected to heater pin 3 on the expansion header.
        Also confirm that you are actually running firmware 3.1.1 by sending M115.
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
          That is was a pass , the bltouch is lit up so i guess it can only be the wire to heater 3 pin 8
          • peter247undefined
            peter247 @Phaedrux
            @Phaedrux I was using heater 7 before on rrf 2 , so moved the control pin to heater 7 and it works.
            • A Former User?
              A Former User
              The most important step I think you are missing is the following.
              Hold the bl-touch in your hand walk over to the bin and drop it in, job done, they are the most unreliable P.O.S. Known to man failure of moving parts, terrible resolution and questionable repeatability.
              Prepare your bed surface properly and use an IR sensor.
                Phaedrux Moderator @A Former User
                @CaLviNx said in rrf3 bltouch what have a missed.:
                He didn't have it plugged in. Hardly the fault of the probe.
