makerbot repliactor 2 conversion
  • Makerbot
    hello im trying to have my makerbot replicator 2 use a duet board. I saw this idea from someone and luckly they posted the files so i gave it a shot. IMm trying to get my board to home but now getting the error when homing any axis "g0/g1 insufficient axes home. here the homexconfig. its a bit odd looking from looking at others but cant find the problem. here was the orginal place i found the idea https://forum.duet3d.com/topic/1946/makerbot-replicator-2x-duetwifi-edition/2
    ; homex.g
    ; called to home the X axis
    ; generated by RepRapFirmware Configuration Tool on Sat Jul 01 2017 14:45:41 GMT+0800 (Malay Peninsula Standard Time)
    ; Lift Z relative to current position
    G91
    G1 Z5 F150000 H2
    G90
    ; Move quickly to X axis endstop and stop there (first pass)
    G1 X-290 F1800 H1
    ; Go back a few mm
    G91
    G1 X5 F150000
    G90
    ; Move slowly to X axis endstop once more (second pass)
    G1 X-290 F360 H1
    ; Lower Z again
    G91
    G1 Z-5 F150000 H2
    G90
  • @jxgreer please post config and homeall and which hardware and firmware version you use. Are any axis homed, which axis do not home?
  • Moderator
    What firmware version are you running on the Duet? Send M115 to check. Should be either 2.05.1 or 3.1.1.
    I'm guessing you're running an older version that doesn't support the H2 switch on G1 moves.
  • Moderator
    @jxgreer I expect you’re using an old versions of the firmware that doesn’t support the H parameter in G1 moves (RRF 2.01 or earlier). Send M115 to the Duet and post the response. Post your config.g too, as that may be set up for a particular firmware, too.
  • Moderator
    @Phaedrux snap!
  • Moderator
    JYNX! 🤠
  • Moderator
    @Phaedrux actually, @JoergS5 got there before us!
  • heres the config file and home all @JoergS5
    ; Configuration file for Duet WiFi (firmware version 3.1.1)
    ; Modified from V3 config.g on 4-06-2020
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X-10 Y0 Z0 S1 ; Set axis minima (bed offset 12 and 10 from zero)
    M208 X252 Y142 Z150 S0 ; Set axis maxima (reduced by offset above)
    ; Enable Panel Due Connector
    M575 P1 S1 B57600 ; Enables connector and sets baud rate
    Endstops- Switches
    M574 X1 S1 P"!xstop" ; X min active high endstop switch
    M574 Y1 S1 P"!ystop" ; Y min active high endstop switch
    M574 Z1 S1 P"!zstop" ; Z min active high endstop switch - Config for hard Z Endstop
    ; Endstops- Z Probe
    ; M574 X1 S1 P"!xstop" ; X min active high endstop switch
    ; M574 Y1 S1 P"!ystop" ; Y min active high endstop switch
    ; M574 Z0 S1 P"!zstop" ; Z min active high endstop switch - Config for Z Probe
    ;NPN Sensor
    : M558 P5 C"zprobe.in" X0 Y0 Z1 H5 I1 F200 T150000 ; NPN Capacitive Probe probe on ZProbe Connector, the axes for which it is used and the probe + travel speeds
    ;M558 P5 X0 Y0 Z1 H5 I1 F200 T150000 ; NPN Capacitive Probe probe on ZProbe Connector, the axes for which it is used and the probe + travel speeds
    : G31 P500 X-38 Y2 Z1.29 ; Set Z probe trigger value, offset and trigger height - Increase Z value to move bed closer to nozzle
    M557 X5:204 Y3:242 S20 ; Define mesh grid
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P4 S1 ; Drive 4 goes forwards
    M92 X88.573186 Y88.573186 Z400 E96.27520187033366 ; Set steps per mm
    M566 X900 Y900 Z300 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X1080000 Y1080000 Z600 E96000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z100 E2000 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z400 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S260 ; Set maximum heater temperature to 260C
    M308 S0 P"bed_temp" Y"thermistor" T100000 B3974 C0 R4700 ; Set thermistor + ADC parameters for heater 0
    M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    ; M308 S2 P"e1_temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
    M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
    M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
    ; M950 H2 C"e1_heat" T2 ; heater 2 uses the e0_heat pin and sensor 1
    M307 H0 A103.7 C787.7 D1.0 S1.00 B0 ; Set PID values for Heatedbed - derived from autotune
    M307 H1 A313.9 C153.8 D4.0 S1.00 B0 ; Set PID values for Extruder 1 - derived from autotune
    ; M307 H2 A352.7 C171.2 D3.5 S1.00 B0 ; Set PID values for Extruder 2 - derived from autotune
    M563 P0 D0 H1 ; Define tool 0
    ;M563 P1 D1 H2 ; Define tool 1
    ;G10 P1 X35 Y-0.8 Z0 ; Set tool 1 axis offsets
    ;G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
    M207 S1.2 F1200 ; set 1.2mm retract distance for G10 command
    M550 P"Duet_Rep2X" ; Set machine name
    ;M551 P"XXXXX" ; Set password
    M552 S1 ; Enable network
    ;M552 P192.168.0.98 ;Fixed IP Address
    ;M554 P192.168.0.1 ;Gateway
    ;M553 P255.255.255.0 ;Netmask
    ; Access point is configured manually via M587 by the user
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Enable FTP
    M586 P2 S0 ; Disable Telnet
    M950 F0 C"fan0" Q500 ; Set fan 0 value, PWM signal inversion and frequency.
    M106 P0 H-1 ; Set fan 0. Thermostatic control is turned off
    M106 P0 S0 ; Switch cooling fan off
    M950 F1 C"fan1" Q500 ; Set fan 1 value, PWM signal inversion and frequency.
    M106 P1 H1 T45 ; Set fan 1 Thermostatic control turned on
    ;M950 F2 C"fan2" Q500 ; Set fan 2 value, PWM signal inversion and frequency.
    ;M106 P2 H2 T45 ; Set fan 2 Thermostatic control turned on
    and heres the home all
    ; homeall.g
    ; called to home all axes
    ; Relative positioning
    G91
    ; Lift Z
    G1 Z5 F600 H2
    ; Course home X and Y
    G1 X-290 F1800 H1
    G1 Y-155 F1800 H1
    ; Move away from the endstops
    G1 X5 Y5 F150000
    ; Fine home X and Y
    G1 X-290 Y-155 F360 H1
    ; Code for Hard Endstop home Z
    ; Move Extruder out of the way
    ;G90
    ;G1 X-12 Y-10 F150000
    ; Home Z against hard enstop
    ;G91
    ;G1 Z-200 F400 H1 ; rough home Z axis
    ;G1 Z2 F400 ; move down by 2mm
    ;G1 Z-155 F40 H1 ; fine home z axis
    ; Adjust Z distance from Z endstop
    ;G92 Z0.00 ; positive - Move bed closer to extruder, negative - Move bed away from extruder
    ; Absolute positioning
    G90
    ; Code for Sensor Based Z Homing
    ; Go to first bed probe point and home Z
    G1 X156 Y64 F150000
    G30
    ; Uncomment the following line to lift the nozzle after probing
    G1 Z5 F300 H2
    @Phaedrux FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3
  • Moderator
    Your config is for RRF3, and your installed firmware is 2.0.
    From the web interface, upload the following zip files to the /sys folder one at a time. This should trigger a firmware update and update the DWC files as well after each one.
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
    Once you've updated all 3 you should send M115 to verify that you're on 3.1.1. Then send M98 P"config.g" to see if any errors are generated from your config.g and report them here for further troubleshooting.
  • This post is deleted!
  • @Phaedrux also looks like now i can move it. when i press home it moves a bit but doesnt go to the sensors on any of the axis.
  • I just did that swap, from a replicator 2 to duet 3. check your chat Ill help you set it up
