    Drive 0 value in DWC?
    Duet Web Control
    • arhiundefined
      arhi
      What is this Drive 0 value? 19934.9 on the picture?
      I am using relative extrusion distance in g-code, what is this value? mm's extruded since reboot? or ?
      • baird1faundefined
        baird1fa
        Drive 0 is your extruder. It is how many mm it has moved in the current print. It doesn’t matter if you use relative or absolute or continuously reset the extruder to 0 in your GCode. It keeps track of how much filament was used so far in the print. It resets to zero each print.
        arhiundefined 1 Reply Last reply Reply Quote 1
        • arhiundefined
          arhi @baird1fa
          @baird1fa said in Drive 0 value in DWC?:
          cool so when I start print from SD it will start from 0 and count till the end of the print. Thx.
          • deckingmanundefined
            deckingman @arhi
            @arhi said in Drive 0 value in DWC?:
            I think so too. I believe that's what DWC uses to give the estimated completion time based on filament usage.
