Solved Sammy-C21 CAN errors
It's been over a month since I tested the SammyC21 firmware build. I've just built and loaded the debug build through ICE and I am getting the same issue - no CAN connection. I'll fix this today if i don't run out of time.
Currently, the release build works (loaded over CAN by the bootloader), but the debug build loaded via the ICE doesn't.
I've just fixed the SammyC21 debug build and committed the fix to github. The main change was in the .cproject file, and I had to do a clean and then a build to get the change included in the binary.
Works, Thanks a million @dc42, now on to calibration.
