    Homeing does not work - fadeing x Endstop
    Firmware installation
    1.2k
    • humbleJoeundefined
      humbleJoe
      Sended M115; Response: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2019-06-13b2
      Config File:
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Jul 18 2020 12:48:35 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P""                             ; set printer name
      M918 P1 E4 F2000000                                ; configure direct-connect display
      M551 P""                               ; set password
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0 S0                                         ; physical drive 0 goes backwards
      M569 P1 S0                                         ; physical drive 1 goes backwards
      M569 P2 S0                                         ; physical drive 2 goes forwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X235 Y235 Z260 S0                             ; set axis maxima
      M574 X1 Y1 Z1 S1                                   ; set active high endstops
      M307 H4 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000                              ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M305 P0 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 0
      M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
      M305 P1 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 1
      M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
      M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:0 T45                        ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      I have a name and password, but I deleted it only in this post 🙂
      -if you see anything where i should add / change something... feel free to tell me - I am a reprap noob
      Joe
      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @humbleJoe
        @humbleJoe said in Homeing does not work - fadeing x Endstop:
        M918 P1 E4 F2000000
        Direct connect display (eg 12864) is not supported on Duet 2 Wifi, only Maestro. Well, it sort-of is, but you need an adapter board and a special version of the firmware. If you've connected a screen, disconnect it.
        That is an old version of the firmware, ideally update to the latest v2 firmware, which is 2.05.1. But your config.g should work with it.
        Generally, I can't see much wrong with your config.g. Please check your X endstop is wired correctly, as I think it's most likely that's what's causing the problem. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Connecting_different_types_of_endstop_switch
        You could try swapping the X and Y endstop connection, and see if the behaviour swaps to the Y axis.
        Finally, at the moment your homing files are not set up to use the BLTouch for homing Z; they're using a Z endstop. Replace these lines in homeall.g and homez.g:
        G1 H1 Z-265 F240        ; move Z down stopping at the endstop
        G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
        with
        G1 X15 Y15 F6000        ; go to first bed probe point and home Z
        G30                     ; home Z by probing the bed
          humbleJoe
          So my homez.g now looks like:
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Jul 18 2020 12:48:36 GMT+0200 (Mitteleuropäische Sommerzeit)
          G91               ; relative positioning
          G1 H2 Z5 F6000    ; lift Z relative to current position
          ;G91              ; relative positioning
          ;G1 Z5 F100       ; lift Z relative to current position
          ;G90              ; absolute positioning
          and the homeall.g is
          ; homeall.g
          ; called to home all axes
          G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-240 Y-240 F240  ; move slowly to X and Y axis endstops once more (second pass)
          Is that correct 🙂 ?
          And the endstop is wired like this: on the duet mainboard only the two outer pins, (GND, 3v3, X Stop). on the ender 3 side i have the following pinout: (Signal, Ground, 3v3). So I wired GND -> GND, X Stop -> Signal and both 3v3 are not used.
          Thx for the help.
          Joe
            humbleJoe
            So I now changed the X Endstop with the Z Endswitch because I dont use it anymore. It still doesnt work.
            After changing the lines shown in the last 2 posts I tryed to only home Z.
            The Z axis only moved some milimeters positive direction and then stopped and the webpage gave me this error.
            If I press home all the x axis moves some mm, the y as well (both x and y home buttons then switch to homed) and then the Z axis starts moveing down and never stops, the BL Touch also dont work correct, it was always closed / triggered - like it behaves while printing.
            So i had to emergency stop just before the print had reached the bed - cause it would not have stopped.
            This error came after restart
            98c9f5c4-cc7f-438a-a5c5-d18cf65a26c3-grafik.png .
            FYI: When I power on the printer the BL Touch does this start process where it tests that it can trigger correct and that works every time.
            -> can someone tell me what the F is wrong with my setup? Before I switched from the Creality Mainboard v. 1.1.5 everything worked fine so I would guess all this behaviour must be from mistakes in wireing or firmware.
            however I feel like the wiring is as it is shown in the wiki.
              Phaedrux Moderator @humbleJoe
              M307 H4 A-1 C-1 D-1
              Where do you have the BLtouch wired up to? H4 is certainly incorrect. It should either be heater pin 3 or 7. Without that being correct you can't deploy or retract the pin.
              humbleJoeundefined 1 Reply Last reply Reply Quote 0
                humbleJoe @Phaedrux
                @Phaedrux said in Homeing does not work - fadeing x Endstop:
                M307 H4 A-1 C-1 D-1
                You are correct, it is H3/ Pin 8. I connected the BL Touch the recommended way from the wiki:
                Thx for this hint - this was an user error ^^.
                I will fix this after work and also review the rest of my code configurations before I waste your time 🙂
                  humbleJoe
                  so here is an Update:
                  after getting the BL Touch right and fixing the following files:
                  config.g
                  M307 H3 A-1 C-1 D-1
                  M558 P9 H5 F100 T2000
                  G31 X0 Y0 Z0 P25
                  deployprobe.g
                  M280 P3 S10 I1
                  retractprobe.g
                  M280 P3 S90 I1
                  Here is what happens:
                  When I home X and Y axis, the printhead moves z positive, some mm (less then 5) into x/y positive direction (my endstops are low end/ so other direction and will never get triggered) and then z negative and stops there.-> he thinks the home was a success!
                  The Z homeing works now (or at least it tests it once, the second / faster test doesnt work).
                  After homeing all axis (doesnt matter if allhome/ or to home 1 by 1) the printer thinks that the point he is at the moment is his home (even if it is in the middle of the build plate because he never drives to the endstops). So i can move the X and Y axis only in more positive direction but not nevative (as long as I dont move positive first. then I am able to drive as much negative as I did positive before.)
                  Edit:
                  One other thing about the endstops. at the moment I used normaly open switches because i was not able to use normaly closed once - changeing the 1 to 0 and 0 to 1 in the config.g made no diffrence
                  Endstops
                  M574 X1 Y1 Z1 S1
                  same behavior as
                  Endstops
                  M574 X0 Y1 Z1 S1
                  How can this be?
                  Any tipps what I can do next 🙂
                  • fcwiltundefined
                    fcwilt
                    So when you home X or Y the result is some small movement on X or Y in the positive direction.
                    Correct?
                    If so that is because your end stops are already triggered when the home begins.
                    • The 1st move in the negative direction never happens because the end stop is triggered
                    • The 2nd move in the positive direction happens as expected giving the 5 mm of movement in the positive direction
                    • The 3rd move in the negative direction never happens because the end stop is triggered
                    Try changing the M574 command to specify active low if it is now active high (or vice versa).
                      humbleJoe
                      well thx for this hint. I directly homed again while holding the x endstop and it works as it should until I let it again.
                      So now my question is why is it that my machine thinks he is always triggered even when the Endstop LEDs are not shineing. -> why doesnt it work when i change the M574 command from X0 to X1 or other direction or die S1 to S0?
                      Greetings
                      Joe
                      Edit:
                      I use NO Switches with 2 wires. So I wired only the 2 outer pins as said in this wiki: https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet+2+WiFi-Ethernet/9?lang=en
                      And I have the config.g as posted above. what would be the correct commands for my ender 3 with this setup? can anybody tell me I will test it then 🙂
                      • fcwiltundefined
                        fcwilt
                        In the M574 the number after the X,Y,Z specifies if the end stop is at the low or high end of the axis range.
                        S1 specifies an active high input, S0 specifies active low.
                        You need to use S0 since your switches, when closed, connect the input to ground.
                          humbleJoe
                          Ok, then I have understood that correctly. So here is my endstop config from config.g
                          Endstops
                          M574 X1 Y1 Z1 S0
                          and this is how i wired the x and y endstops on the duet:
                          this is how both endstops (normaly closed) are connected:
                          but they behave weird. When I interrupt the connection (pushing the trigger or just disconnect the switch) the red LED goes off and i am able to home correct. -> so the FW works as NO Switches.
                          Here I have the x-endstop just connected and the board thinks it is triggered when it is not, but the disconnected y is not "triggered".
                          In my understanding it shouldnt behave like this - might there be an overwrite file where I also have to change something because inverting the config.g to S0 or S1 makes both no diffrence in behaviour.
                          But when I change thw wires on the switch side to NO it works fine. How ever I want to use them in NC mode.
                          BTW can i scale the images down in this view ? that i dont spam pages ?
                          Joe
                            Where are your endstops actually located? Left/right front/back?
                            Low end of travel is to the left, high end to the right.
                            Low end to the front, high end to the back.
                            -x to the left, +x to the right.
                            -y to the front, +y to the back.
                            Your homeall file is setup for the switches to be at the low ends of travel. Is that still the case?
                            What does your M574 line look like now?
                            For the Ender 3 pro in RRF2 it should be M574 X1 Y1 Z1 S1
                              humbleJoe
                              I havent changed anything on the positioning of the ender 3 pro switches. So when I look at my printer the x is on left side and the y on the back.
                              In the config.g file the M574 command is
                              M574 X1 Y1 Z1 S1
                              Ok for reasons that I dont understand the homeing process now works as intended. exept for one little detail. it trys to home the z axis with the BL Touch on spot near the x endstop so out of the heated bed. How do I fix this :)?
                              The x & y endstop LED is always on when not triggered. I asume that is fine?!
                              When Y triggered the LED goes off how ever when X is triggered the LED goes from bright shine to low dimmed but not off. -> is that a problem / do you guys have that behavior as well?
                              Joe
                              DIY-O-Sphereundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • DIY-O-Sphereundefined
                                DIY-O-Sphere @humbleJoe
                                Edit x and y position in homeall.g and homez.g
                                (UTC+1)
                                • fcwiltundefined
                                  fcwilt @humbleJoe
                                  For this purpose I would do it at the center of the bed.
                                  Now I prefer setting up axis min/max values so 0,0 IS the center of the bed.
                                  So for my FT-5 with a 300x300 bed the X and Y axis min/max values are -150/150.
                                  IF I kept 0,0 at the left-front corner the X and Y axis min/max values would be 0/300.
                                  In that case to probe at the center I would have to use 150,150.
                                  Someone else has suggested using the first probe point at 15,15 - not sure why you would want to do that.
                                    humbleJoe
                                    Looks good now, changed x & y to 118 (235/2).
                                    So thank you all for helping me 🙂
                                    However one last point. It looks like my Extruder is not set up correctly.
                                    I cant extrude or retract something an when clicking on it I get the following error.
                                    Joe
                                      Select a tool first by either clicking on the tool, or sending T0. Most people add a T0 to the end of config.g so that it's selected at start up. It also must be at temp to extrude unless you've specifically allowed cold extrusion.
                                        humbleJoe
                                        Thank you all so much. Works everything fine now.... I will read some more wiki and learn all this machine code 🙂 but thank you all for the support 🙂
                                        Greetings and have good prints!
                                        Joe
