Toolboard 1LC Heater voltage
Quick question about the toolboard with 24V supplied to the board. I know the fans are 12V, but is the heater voltage at 24V or 12V?
Thanks
Output Out0 uses Vin while Out1 and Out2 uses 12v.
So with Vin=24v the heater would be 24v.
Great, thank you. I have some toolboards coming and needed to know if I had to order different heaters or not.
@T3P3Tony , might want to add this to your documentation, there's no mention of this in either the new or old docs.
@aquilux thanks, I have added that to the hardware specification and description of connections in the docs:
