Typo error in documentation.
  • @dc42
    Have just noticed this typo error in the Gcode documentation:
    M851: Set Z-Probe Offset (Marlin Compatibility)
    RepRapFirmware 2.02 and later
    M851 Znn is implemented for backwards compatibility with other firmware. It sets the Z probe trigger in the same way as G31 Z-nn (note the sign reversal). It also flags the Z-probe G31 parameters as to be saved in config-override.g if the M500 command is used.
    G31 should be used in preference to M581.
    Obviously it should refer to M851 not M581.
  • Moderator
    @chas2706 Thanks, fixed.
