    Move axis without homing
    • pjn2973
      pjn2973 last edited by
      I recently started building a CoreXY printer, first printer being built entirely from scratch and first time using a Duet3D product. Built the frame and have put just the basics for the XY axis together, i.e. timing belts, steppers, rails. Have not put any limit switches or Z axis together yet.
      When I connect the motors to the board, and power up, the board indicates that the various axes are not yet homed, which is correct. I am hoping to just move the XY axes to insure that I have the configuration and building of the XY correct. Is there a way to do this without homing all axes?
      JoergS5 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt last edited by
        Check out M564.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
        Printers: A FT-5 with the 713 upgrade bits, a custom MarkForged style, a small Utilmaker style, a small CoreXY from kit and a E3D MS/TC setup. Various hotends. Using Duets (2 and 3) running 3.4.6
        • JoergS5
          JoergS5 @pjn2973 last edited by
          @pjn2973 to test the single CoreXY especially, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
          The G1 S parameters are replaced by H parameters for RRF 3.
            https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4?_=1595628809652
            Core XY can get confusing. Take a look at that post to try and keep it straight.
            • pjn2973
              Thanks, guys; finally got back to this. Got the motors to move and test correctly using all of the information you posted. 🙂
