    ender 5 plus
    1.4k
    • Kevinundefined
      Kevin
      i am working on an ender 5 plus with a duet wifi
      but I have a problem
      when I am home x, y I cannot go to the minus position only the plus position
      but am already at end stops (right rear)
      i'm still figuring out files
      z home.g
      homeall.g
      and independent z axes (P2 left z axes: P4right z axes)
        Take a look at the following posts.
        https://forum.duet3d.com/topic/12676/mirrored-x-axis/9
        https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4
        If you go through the steps outlined in those posts an identify where 0,0 should be, and then where the endstops are located physically and configured correctly in M574 then you can check motor direction so that -x goes to the left and -y goes to the front. Then the direction of the homing moves may need to be changed to move the correct direction to the endstops.
        If you still can't figure it out, post your config and homing files.
        • Kevinundefined
          Kevin
          I have been busy with it continue to have problems
          the M569 drivers the driver rotation is good,
          when i home x,y go to the good rotation right back corner
          home x, y i can move them after when amhomeall.g send M564 S 0
          home z is problems ;G28 Z
          Error: Z probe already triggered at start of probing move
          home all same problem first home x,y,z send m564
          then i can do the home all axis
          sorry for me bad english i translate with google translate
          homex.g homey.g homez.g homeall.g
            Post your config.g as well.
            With 0,0 in the front left corner does -x go to the left and -y go to the front?
              What firmware version are you using? Can you post the results of M122 as well?
              • Kevinundefined
                Kevin
                in config.g I have M208 on x0 y0
                home x, y is going in the right direction, but no response after home should send M564 S0
                then I can move axes in dwc -x left and -y forward
                config.g
                Firmwareversie: 2.03 (2019-06-13b2)
                WiFi-serverversie: 1.23
                Webinterfaceversie: 1.22.6
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                Board ID: 08DLM-996RU-N8PS4-7JKFA-3S86L-9BABN
                Used output buffers: 3 of 24 (15 max)
                Static ram: 25680
                Dynamic ram: 93688 of which 0 recycled
                Exception stack ram used: 452
                Never used ram: 11252
                Tasks: NETWORK(ready,468) HEAT(blocked,1236) MAIN(running,3744) IDLE(ready,160)
                Owned mutexes:
                Last reset 01:51:45 ago, cause: power up
                Last software reset at 2020-07-28 10:13, reason: User, spinning module GCodes, available RAM 11300 bytes (slot 2)
                Error status: 0
                Free file entries: 10
                SD card longest block write time: 3.3ms, max retries 0
                MCU temperature: min 34.3, current 34.5, max 34.8
                Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, SG min/max 0/193
                Driver 1: standstill, SG min/max 70/406
                Driver 2: standstill, SG min/max 0/428
                Driver 4: standstill, SG min/max 0/428
                Date/time: 2020-07-28 13:32:11
                Slowest loop: 75.94ms; fastest: 0.08ms
                Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 324808ms
                === DDARing ===
                Scheduled moves: 35, completed moves: 35, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 200.39ms; fastest: 0.08ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  Failed messages: pending 0, notready 0, noresp 2
                  WiFi firmware version 1.23
                  WiFi MAC address 84:0d:8e:ad:73:9d
                  WiFi Vcc 3.42, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24904
                  WiFi IP address 192.168.178.19
                  WiFi signal strength -75dBm, reconnections 0, sleep mode modem
                  You should update your firmware to 2.05.1
                  Upload this zip file as is (do not extract it) to the /sys folder
                  • Kevinundefined
                    Kevin
                    i just updated to
                    Firmwareversie: 2.05.1 (2020-02-09b1)
                      Phaedrux Moderator @Kevin
                      @Kevin said in ender 5 plus:
                      What type of Z probe are you trying to use?
                      Your homeall is setup to use a probe and then the endstop, which is not ideal. You also should not need to have a U axis at all. Your maxima is set to negative values and your endstops aren't configured for the right location.
                      Try making the following changes to your config.g homeall.g and homez.g files. You can copy and paste my text over yours.
                      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 20:35:09 GMT+0200 (Midden-Europese zomertijd)
                      M550 P"Ender 5+"                                   ; set printer name
                      M569 P0 S0                                         ; physical drive 0  X
                      M569 P1 S0                                         ; physical drive 1  Y
                      M569 P2 S0                                         ; physical drive 2  Z LEFT
                      M569 P3 S0                                         ; physical drive 3  EXTRUDER 0
                      M569 P4 S0                                         ; physical driver 4 Z RIGHT
                      M584 X0 Y1 Z2:4 E3                           ; Driver 0 For X, 1 for Y, Z=2:4
        ; Motor remapping for dual Z
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X80 Y80 Z1600 E105.00                    ; set steps per mm
                      M566 X900 Y900 Z60 E300                     ; set maximum instantaneous speed changes (mm/min)
                      M203 X180000 Y180000 Z1200 E12000            ; set maximum speeds (mm/min)
                      M201 X600 Y600 Z60 E1000                       ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E800 I20                  ; set motor currents (mA) and motor idle factor in per cent
                      M208 X0 Y0 Z0 S1                                ; set axis minima
                      M208 X333 Y350 Z400 S0                      ; set axis maxima
                      M574 X2 Y2 S0                                ; set active low and disabled endstops
                      M574 Z1 S2                                      ; Set active high endstops
                      M558 P1 H5 F300 T6000 B1                           ; disable Z probe but set dive height, probe speed and travel speed
                      G31 P500 X0 Y-45 Z0.855                            ; Set Z probe trigger value, offset and trigger height
                      M557 X60:300 Y30:300 S30                           ; define mesh grid
                      M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
                      M143 H0 S100                                       ; set temperature limit for heater 0 to 120C
                      M305 P1 T500000 B4723 C1.196220e-7 R4700           ; set thermistor + ADC parameters for heater 1
                      M143 H1 S300                                       ; set temperature limit for heater 1 to 300C
                      ; Bed adjustment screw locations
                      ;M671 X316:316:46:46 Y295:35:295:35                 ; mark leveling screws at (316,295) (316,35) (46,295) (46,35)
                      M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off (part cooling)
                      M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on  (hotend)
                      M106 P2 H100:101 T45:55 L0.3                       ; set fan 3 value, pmw signal intersion and frequency. thermostatic control is turned on  (case fan)
                      G10 P0 X0 Y0 Z0 U0                                  ; set tool 0 axis offsets
                      T0
                      ; homeall.g
                      ; called to home all axes
                      G1 H2 Z2 F6000          ;lower bed  2mm
                      G1 H1 X355 Y355 F3000   ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X-5 Y-5 F6000     ; go back a few mm
                      G1 H1 X355 Y355 F360    ; move slowly to X and Y axis endstops once more (second pass)
                      G1 X175 Y175 F6000    ; move to center of bed
                      G30                     ; lower head, stop when probe triggered and set Z to trigger height
                      G1 X10 Y10 Z10 F6000		  ; move Z to Z=1
                      With this new config file and homeall test to make sure the motors are still going in the correct direction. -x to the left, +x to the right, -y to the front, +y to the back. If the direction isn't like that you will need to reverse the motor direction in M569 for either axis.
                      Once the machine is homing correctly with the probe you can then move on to doing bed tilt correction using this method.
                      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                      • Kevinundefined
                        Kevin
                        i am using the DC42's IR sensor for z switch / probe
                        i am going to try your files from config.g and home files
                        • Kevinundefined
                          Kevin
                          This post is deleted!
                          • Kevinundefined
                            Kevin
                            now it works home is right back corner
                            • goes left + goes right
                            home = x330 y350
                            0,0 left front corner
                              Ok good, that sounds correct now.
                              Is the probe working?
                              • Kevinundefined
                                Kevin
                                probe works with height .
                                now I can find out further with homez.g
                                thanks for the quick responses
                                  For your home Z, I would change it to just home the Z axis with the probe. Then use G32 which calls bed.g to do the tilt correction as described in the link I provided above. You'll need to add M671 command to your config.g that defines the position of the lead screws and then configure bed.g to probe at two locations close to the lead screws. The link describes it in more detail.
                                  • Kevinundefined
                                    Kevin
                                    I've been working on the Bed leveling with multiple independent Z motors
                                    config:
                                    M671 X-20: 370 Y0: 0 S2; leadscrew locations
                                    (if this is correct left x-20/y200 right x350(max)/y200)
                                    bed.g:
                                    M561; clear any bed transform
                                    G30 P0 X5 Y165 Z-99999; probe near a leadscrew left
                                    G30 P1 X325 Y165 Z-99999 S2; probe near a leadscrew right
                                    but after G32 only the left drops and does not rise after a few tries this is the result
                                    G32
                                    Leadscrew adjustments made: -0.571 0.573, used points 2, deviation before 0.470 after 0.000
                                    G32
                                    Leadscrew adjustments made: -0.320 0.350 , points used 2, deviation before 0.275 after 0.000
                                    M98 P "0: / macros / G32 HOME"
                                    Leadscrew adjustments made: -0.193 0.182, points used 2, deviation before 0.154 after 0.000
                                    after each g32 left sinks and tilts the bed
                                    what am I doing wrong?
                                      Please post your entire config.g
                                      Which Z motor driver is on which side of the bed? The order of the driver needs to match the order of the points to probe.
                                      You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command.
                                      • Kevinundefined
                                        Kevin
                                        config (1).g
                                        bed.g
                                        M569 p2 is the lefts side.
                                        M569 p4 is the right side
                                          Can you post a video of it in action?
                                          • Kevinundefined
                                            Kevin
                                            I try to uploud the movie but the files are too big
