    ender 5 plus
    1.5k
    • Kevinundefined
      Kevin
      i am using the DC42's IR sensor for z switch / probe
      i am going to try your files from config.g and home files
      • Kevinundefined
        Kevin
        This post is deleted!
        • Kevinundefined
          Kevin
          now it works home is right back corner
          • goes left + goes right
          home = x330 y350
          0,0 left front corner
            Ok good, that sounds correct now.
            Is the probe working?
            • Kevinundefined
              Kevin
              probe works with height .
              now I can find out further with homez.g
              thanks for the quick responses
                For your home Z, I would change it to just home the Z axis with the probe. Then use G32 which calls bed.g to do the tilt correction as described in the link I provided above. You'll need to add M671 command to your config.g that defines the position of the lead screws and then configure bed.g to probe at two locations close to the lead screws. The link describes it in more detail.
                • Kevinundefined
                  Kevin
                  I've been working on the Bed leveling with multiple independent Z motors
                  config:
                  Bed adjustment screw locations
                  M671 X-20: 370 Y0: 0 S2; leadscrew locations
                  (if this is correct left x-20/y200 right x350(max)/y200)
                  bed.g:
                  M561; clear any bed transform
                  G30 P0 X5 Y165 Z-99999; probe near a leadscrew left
                  G30 P1 X325 Y165 Z-99999 S2; probe near a leadscrew right
                  but after G32 only the left drops and does not rise after a few tries this is the result
                  G32
                  Leadscrew adjustments made: -0.571 0.573, used points 2, deviation before 0.470 after 0.000
                  G32
                  Leadscrew adjustments made: -0.320 0.350 , points used 2, deviation before 0.275 after 0.000
                  M98 P "0: / macros / G32 HOME"
                  Leadscrew adjustments made: -0.193 0.182, points used 2, deviation before 0.154 after 0.000
                  after each g32 left sinks and tilts the bed
                  what am I doing wrong?
                    Please post your entire config.g
                    Which Z motor driver is on which side of the bed? The order of the driver needs to match the order of the points to probe.
                    You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command.
                    • Kevinundefined
                      Kevin
                      config (1).g
                      bed.g
                      M569 p2 is the lefts side.
                      M569 p4 is the right side
                        Can you post a video of it in action?
                        • Kevinundefined
                          Kevin
                          I try to uploud the movie but the files are too big
                            dropbox, or google drive, box, onedrive, youtube, vimeo, something like that.
                            • Kevinundefined
                              Kevin
                              oke i go try
                              • Kevinundefined
                                Kevin
                                https://youtu.be/RuRSe_RKp9U
                                https://youtu.be/aUn8AIXxMeU
                                1 movie is home and then g32 several times
                                  Are you using a macro called G32 HOME? Or are you using just G32 (which calls bed.g)?
                                  • Kevinundefined
                                    Kevin
                                    i tried both normal G32 (bed.g) and macro G32 same settings as bed.g
                                      It's hard to really see any movement in the video. I can't tell if it's actually making an adjustment or not. Is it?
                                      If you purposely introduce an exaggerated tilt, does it try to correct it?
                                      peter247undefined 1 Reply Last reply Reply Quote 0
                                      • peter247undefined
                                        peter247 @Phaedrux
                                        @Phaedrux Sorry don't want to hijack this post , but I'm thinking I may finish up doing the same thing with the bltouch and the ender 5 +
                                        What does bed level do ? probe the centre of the bed and set both corner to this level ?.
                                        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                                        • Kevinundefined
                                          Kevin
                                          he only adjusts the lowest side and always down not flat.
                                          when I raise right goes left after bottom,
                                          when I raise left goes right after bottom
                                          https://youtu.be/XKS44LAiNmA
                                            ; Bed adjustment screw locations
                                            M671 X-20:370 Y0:0 S2 ; leadscrew-locaties
                                            I don't think your Y coordinate is correct. Your lead screws are in the middle of the bed along the Y axis, not at the front. According to your bed.g it should be Y165:165
                                            I don't think that matters in this case, but it's something I noticed.
                                            Your driver order looks correct to match your lead screw positions. Can you double check that the left motor is connected to driver 2 and the right to driver 4? The behaviour seems to indicate it's doing the reverse of what it should, and having the drivers reversed would do that.
                                            The only other thing I can think of is maybe the IR probe not liking your build plate surface. Can you show a photo of the bed surface? Can you try putting a piece of plain white paper under where the probe samples?
