    an8 blv mod duet 2 wifi calibration
    • morf33undefined
      morf33
      good day ok i got a question . i got my duet working bl touch and all i printed a 20mm x 20mm test cube .
      sliced in cura . cura shows its right 20 x 20 mm . i do a print and my x and z are good but my y is 25mm
      i verified all my motors are the same model and type . so i am 20mm x 25mm x 20mm cube . here is my config file .
      should i just change my y steps or should i do something else ?
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Jul 23 2020 14:47:56 GMT+0300 (Arabian Standard Time)
      M550 P"Anet A8" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X100.00 Y100.00 Z400.00 E409.00 ; set steps per mm
      M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-10 Y0 Z0 S1 ; set axis minima
      M208 X220 Y190 Z240 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
      ;M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
      M574 Z0 ; configure Z-probe endstop on Z
      M558 P9 C"^zprobe.in" H5 F120 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-42 Y-40 Z1.067 ; set Z probe trigger value, offset and trigger height
      M557 X15:220 Y15:190 S50 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      T0 ; select first tool
      M501
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @morf33
        @morf33 your config looks ok, but for Y you must verify M92 X100.00 Y100.00 Z400.00 E409.00
        Maybe the steps/mm is different, verify the count of your teeth, it may be different.
        16 teeth: 200 steps per rotation * 16 microteps / 32 mm per rotation = 100.
        20 teeth: 200 steps per rotation * 16 microteps / 40 mm per rotation = would be 80.
        Seems you have 20 teeth at the Y stepper and with the M92 you get more distance than planned. (16=>20 is 1/4 more, 20/4 mm is 5 mm more, this would match).
        I would also change M557. You should take into account the probe offset and start M557 with x40 and Y50. I would use more points for mesh compensation (S value lower or use the P parameter), but it depends on how flat your bed is, i.e. how important mesh compensation is for you.
