    RRF Configurator: is it 'pitch' or 'lead'
    • zaptaundefined
      zapta
      A minor issue I encountered while using the RRF configurator (see screenshot below), should 'pitch' be changed to 'lead' ? (they are not the same)
      https://www.thomsonlinear.com/en/support/tips/difference-between-screw-pitch-and-lead
      • A Former User?
        A Former User
        that is probably a glitch in the matrix from the days when pitch and lead were the same. (yeah, i guess pitch is correct for a M5 screw, but not necessarily for a multi-start acme screw)
        you'll want to use lead, i.e. how much travel one revolution gives you.
        zaptaundefined 1 Reply Last reply Reply Quote 0
        • zaptaundefined
          zapta @A Former User
          Thanks @bearer, hopefully whoever can fix it will see this thread.
          BTW, this thread also surfaced a glitch in the forums software:
          • A Former User?
            A Former User @zapta
            @zapta said in RRF Configurator: is it 'pitch' or 'lead':
            new feautre the other day after the maintenance it seems.
            can turn off in your profile settings under notifications.
