    Problem with PanelDue 5i
    • Thaliosundefined
      Thalios
      Having a weird issue with the newly installed Paneldue 5i on my Duet 3 6HC.
      It boots up, i can control some of the duet features but it is stuck at connecting in the top right corner.
      I have updated it to 1.24, and the Duet to 3.1.1 latest.
      I checked that versions are indeed the ones flashed and they are.
      I can home the duet, move axis, I can control hot end, bed, but i get no feedback whatsoever. Like the connection is 1 way.
      I did add the:
      M575 P1 B57600 S1
      That didn't help.
      Then I saw on the forum about adding it double as such:
      M575 P1 B115200 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      Still no luck..
      Anyone?
      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
      Heavily modified Ender 3 Pro (Duet 3 6HC)
      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
      CR-10S Pro V2 (Duet 3 Mini 5+)
      and a bunch of SLA printers..
      • A Former User?
        A Former User
        Once is enough, twice was a workaround a while back.
        The simplest solution is that you've not connected the io0.out(?) pin to the PanelDue Rx pin properly?
        • Thaliosundefined
          Thalios
          Possible, but doubtful unless a wire is broken. Checking now.
          • Thaliosundefined
            Thalios
            Well, sure enough, the green wire was not making connection in the crimp (from factory).
            Recrimped, works!
