    Maestro 3.31 BL and homing issues?!!
    257
    • cabal2000undefined
      cabal2000
      Hi guys.
      I just upgraded my machine with new heatbed, 2 z motors with screw all through and a Hemera. Upgraded to 3.31. I can't seem to get the 2.0 Bltouch working properly, its not deploying (didn't change the wiring, same as before) and for some strange reason when I HOME ALL the head is not going all the way to the left, it is down but not to the left!!!
      ; Configuration file for Duet Maestro (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 29 2020 16:30:43 GMT-0230 (Newfoundland Daylight Time)
      M550 P"Crapster 4.0" ; set printer name
      M669 K1 ; select CoreXY mode
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 P192.168.2.70 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z4000.00 E400.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X320 Y320 Z300 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X60 Y-30 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
        cabal2000
        Oh and whats the gcode is ignore the Home all so I can do some more testing?
          That would be: https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
            Phaedrux Moderator @cabal2000
            @cabal2000 said in Maestro 3.31 BL and homing issues?!!:
            You don't mention what pin you're actually using for the BLtouch servo control, but it's probably heater pin 3 or 7.
            So instead of ^zprobe.mod it should be exp.heater3 or exp.heater7
              cabal2000
              I scraped 3.31 and back to 2.05. must everything is working BUT the homing!!
                Well the bltouch pin was one thing to change.
                I didn't understand the comment about to the left. Can you be more descriptive of the problem?
                Also post your homeall file.
                cabal2000undefined 1 Reply Last reply Reply Quote 0
                  cabal2000 @Phaedrux
                  @Phaedrux Sure!! When i home my CoreXY the head always always travels left and stops at the endstop, then it travels to the front of the printer, left corner to get x0 y0. BUT for some strange reason its not going left, just to the front
                    Well I'd need to see the homeall certainly as well as the physical position of the endstops. (left and front by the sounds of it, which matches your M574 endstop definition).
                    For Corexy you should check the motor direction using this method
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
