    Endstop detection
    1.3k
    • npm1undefined
      npm1
      In marlin, the endstop connections, tell the motor to go the other direction, one the endstop is pressed, in the reprap firmware when i press 100 in x direction it tries to go of the rail by which point the end stop has been triggered,
      is there an issue with my files.
      Please help.
      When i home the axis and manually press the endstop, the endstop command terrminates the current comand and moves on to the next comand
      Kind Regards
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        Endstop switches are normally active only during homing moves. These are G1 moves with the S1 parameter, which you will find in the homing files. So your comment "When i home the axis and manually press the endstop, the endstop command terrminates the current comand and moves on to the next comand" describes the expected behaviour.
        After the printer has been homed, the axis limits set by M208 are enforced to prevent the head trying to move outside the defined dimensions.
        Are you having a particular problem with homing?
        • npm1undefined
          npm1
          i think im having issues addressing the general dimensions of the printer, I've got a printer with a x220 y220 z240, how would i define that ground zero is at the endstop location, and tell it to move from there.
          kind regards
          • deckingmanundefined
            deckingman
            Assuming your end stops are at the axes minima, then in your config.g you have :-
            M208 X0 Y0 Z0 S1 ; set axes minima
            M208 X220 Y220 Z240 S0 ; set axes maxima
            • npm1undefined
              npm1
              @dc42:
              progress on the homing was working well once I made some changes to the maxima of the config.g file provided.
              when i home the y and the x axis, it reaches the endstops, retracts a little then touches the endstop again.
              with the z axis, I just purchased the http://www.ebay.co.uk/itm/5-X-PCS-Obstacle-Avoidance-IR-Sensor-Infrared-Module-Arduino-Raspberry-PI-/262723014158?hash=item3d2b830e0e:g:w3UAAOSwEzxYbjBn, so that the z homing works. and doesn't go throagh the bed
                @npm1:
                That's expected behaviour, it first homes quickly then it re-homes more slowly to get a more accurate homing position.
                @npm1:
                Be careful, you probably won't get a reproducible trigger height with that IR sensor.
                • npm1undefined
                  npm1
                  @deckingman:
                  What does the S1 command do
                  kind regards
                    deckingman
                    @npm1:
                    @deckingman:
                    kind regards
                    S1 sets the minima, S0 or no S parameter will set the maxima. https://duet3d.com/wiki/G-code#M208:_Set_axis_max_travel
                      The S1 parameter says that you are setting minimum coordinates. S0 or no S parameter says you are setting maximum coordinates. The minimum/maximum coordinates are also the ones assumed when a low/high-end endstop switch is triggered during a homing move.
                      • npm1undefined
                        npm1
                        Hia,
                        Thanks for all the help, i have managed to get the printers homing working well on all axis,
                        I just need to wait till the end stops and new ir probe comes, so that the printer works consistently,
                        Would the the IR probe directly from duet3d work out of the box and to what kind of precision?
                        kind regards,
                          Please see https://miscsolutions.wordpress.com/mini-height-sensor-board/ for how to install and use the IR probe. The consistency of repeated probing at the same point is very high and typically limited by the resolution and reproducibility of your Z axis. The trigger height consistency across different areas of the bed depends on the bed surface - see the section on bed surface in the link above.
                          • npm1undefined
                            npm1
                            I have successfully moved forward with this, by telling the printer where 0 is i.e. 0 is at the endstop
                            all so far is good
