    Pause-Resume problem
    • Ethelredundefined
      Ethelred
      The following test code fails to return to the original XYZ. Otherwise the printer is functioning perfectly. Slot 0 same null results. Any ideas how to confirm/troubleshoot/fix this problem ?
      • Ethelredundefined
        Ethelred
        Oops, works fine using G1 instead of G0.
        • OwenDundefined
          OwenD
          Bit hard to answer when the question is deleted, so I'm going to say the answer is 42.
          • fcwiltundefined
            fcwilt @OwenD
            @OwenD said in Pause-Resume problem:
            I concur.
              Restored for posterity.
              I wonder if that's why they call him DC42... He's always got the right answer.
              • A Former User?
                A Former User
                For 3d printing G0 and G1 are the same? I believe laser and/or CNC mode they differ, where G0 will be a rapid move at machine max speed and G1 will move at whatever feedrate specified.
                (also; 42 ... hihi :D)
                  dc42 administrators @A Former User
                  @bearer said in Pause-Resume problem:
                  That's correct; except for one other difference between G0 and G1 on some architectures. A G0 move will not necessarily be done in a straight line, if a curved move is simpler and potentially faster and does not result in Z dropping below the straight-line value. So on a SCARA or Polar machine, the move will not be segmented to approximate a straight-line move, instead it will be executed as a single move.
