    Nozzle will not start low enough to print
    101
    • damaged_goods
      damaged_goods last edited by
      Hi all
      Below is my present config file. After I zero my nozzle and attempt to print, the nozzle will not go low enough to give me a good first layer. It seems to start printing at about 2.2 mm above the bed.
      Please help!
      I am soooo close
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu May 07 2020 15:49:06 GMT-0400 (Eastern Daylight Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X2 Y1 Z0:4 E3 ; set drive mapping
      M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1800.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z0.2 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z120.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X1200 Y1400 Z2400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X1160 Y1430 Z1815 S0 ; set axis maxima
      M574 X1 S3 ; set endstops controlled by motor stall detection
      M574 Y1 S3 ; set endstops controlled by motor stall detection
      M574 Z0 P"nil" ; set endstops controlled by probe
      M558 P5 C"!zprobe.in" H6 F120 T500 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X-30 Y-36 Z0.66 ; set Z probe trigger value, offset and trigger height
      M557 X0:1160 Y0:1430 S200 ; define mesh grid
      M140 H0 ; enable heated bed; map heated bed to heater 0
      ; M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3950
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4138
      ; M950 H0 C"bed_heat" T0
      M950 H1 C"e0_heat" T1
      M950 F0 C"!Fan0"
      M106 P0 S0.5 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      ; Custom settings
      ; X axis sensorless endstop config
      M915 X S5 F0 H172 R0
      ; Y axis sensorless endstop config
      M915 Y S8 F0 H172 R0
      M501
      • fcwilt
        fcwilt last edited by
        I always check the result of G30 to be sure the Z probe is working as expected.
        I have a macro that does something like this
        G90      ; absolute mode
        G1 X# Y# ; move to center of bed - use X and Y values that account for the Z probe offsets
        G30      ; probe bed
        G1 Z#    ; move Z to a specific position
        At this point I verify that Z is in fact at the correct position. Now in my case my measuring device is a 1mm thickness gauge so the Z move is G1 Z1.
        • damaged_goods
          Thank you. I will give that a try.
            What firmware version are you using? M115 to show.
            What is the probe?
            How are you homing? Post your homeall.g
            What do you have in your slicer start gcode?
            damaged_goods 1 Reply Last reply Reply Quote 0
            • damaged_goods
              damaged_goods @Phaedrux last edited by
              @Phaedrux
              /31/2020, 7:27:23 PM M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
              NPN inductive Z probe
              ; homeall.g
              ; called to home all axes
              ; homex.g
              ; called to home the X axis
              G91 ; relative positioning
              ; G1 H2 Z20 F120 ; lift Z relative to current position
              M92 X172.00 ; set movement speed to match m915 H param
              M201 X100.00 ; reduce acceleration
              M566 X100.00 ; reduce maximum instantaneous speed changes (mm/min)
              G1 H1 X-1160 F6000 ; move quickly to X axis endstop and stop there (first pass)
              ; G1 H2 Z-5 F6000 ; lower Z again
              G90 ; absolute positioning
              M92 X80.00 ; set steps per mm back to default
              M566 X900.00 ; set maximum instantaneous speed changes back to normal (mm/min)
              M201 X500.00 ; set ac
              ; homey
              ; G1 H2 Z5 F6000 ; lift Z relative to current position
              M92 Y172.00 ; set movement speed to match m915 H param
              M201 Y100.00 ; reduce acceleration
              M566 Y100.00 ; reduce maximum instantaneous speed changes (mm/min)
              G1 H1 Y-1430 F6000 ; move quickly to Y axis endstop and stop there (first pass)
              ;G1 H2 Z-5:-5 F6000 ; lower Z again
              M92 Y80.00 ; set steps per mm back to default
              M566 Y900.00 ; set maximum instantaneous speed changes back to normal (mm/min)
              M201 Y500.00 ; set accelerations back to normal (mm/s^2)
              ; G1 X5 Y-10 F6000 ; go to first probe point
              ;G91 ; relative positioning
              ;G1 Z5 F120 ; lift Z relative to current position
              ;G90 ; absolute positioning
              The last question, I don't have an answer to. I used my Prusa Slicer but I didn't see a setting for a start code. I suspect it my ignorance of the software is at least one of my issues. Thank you for any help you can give. I am new to DIY printers.
              Phaedrux 3 Replies Last reply Reply Quote 0
                Phaedrux Moderator @damaged_goods last edited by
                @damaged_goods said in Nozzle will not start low enough to print:
                Update your firmware by uploading this zip file as is to the /sys folder.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                  It's in the printers tab.
                    It's quite bizarre to alter your steps per mm in a homing file. What is the reasoning?
                    What position on the bed are you actually probing? The probe should be positioned at the center.
                    How have you measured the trigger height?
                    If you haven't already, see here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    • damaged_goods
                      @Phaedrux thank you. This should be very helpful.
